Snow Cheap Snow Plow
/ Cheap Snow Plow #51
Ernie,
How does that outside woodburner work. I've only seen them in magazines. How many cords of wood do you burn, does it include your hot water. Of course, also post how the PT does with the bucket clearing your path.
Duane
/ Cheap Snow Plow #52
<font color="green"> Our weather forecast 6- 15 inches in our area </font>
Our forecast has been updated a bit - Charlie, you scared yet or are you just "mowing" your snow?
.TODAY...SNOW...HEAVY AT TIMES. SNOW ACCUMULATION OF AROUND 12 INCHES. HIGH IN THE LOWER 20S. NORTHEAST WIND 10 TO 15 MPH....GUSTING TO 30 MPH.
.TONIGHT...SNOW UNTIL MIDNIGHT THEN SNOW LIKELY AFTER MIDNIGHT. TOTAL SNOW ACCUMULATION OF 16 TO 24 INCHES...WITH LOCALLY HIGHER AMOUNTS POSSIBLE. LOW NEAR 20. NORTH WIND 10 TO 15 MPH.
About three inches on the ground and snowing lightly,
Sedgewood
/ Cheap Snow Plow #53
ernie, you need a blade for your 422, i'll sell one cheap /forums/images/graemlins/mad.gif
/ Cheap Snow Plow #54
Duane:
I love my outside woodburner I have used it for about 12 years. I use it as my only heat source for my house and it does heat the hot water for the house. I probably use anywhere from 4 to 6 cords of wood per winter , depending on how cold the weather is and the type of wood I burn. I have 64 acres of property and about 56 acres of that is woods so I have very little cost for heating my home.
The power trac works real good in this snow with just the small bucket, the snow is the light powdery kind you just set the bucket with the lip slightly elevated and go till the snow starts coming up over the top of the bucket then veer off to the side and dump it. Just for the fun of it I took the pt up over the hill on my tram roads for about 1/2 mile to see how it would handle the snow tractionwise, did not use the bucket to plow. There is about 8 inches on the ground , the pt went up over the hill without any problem. I only have the turf tires and no chains. When I got back down to the house the front of the pt was covered with snow, the snow was deeper than the pt's ground clearance in some spots , no traction problems at all. That just goes to prove that the pt is one great little machine.
/ Cheap Snow Plow #55
Hey, Ernie. Sometimes I take my PT out in the yard just to see what it will go through. The deepest I've gone through is 12" last year and the turfs did just fine, but you are right... the front shelf ends up plowing the snow and packing it down the tunnel opening. I'm sure it would get stuck eventually, but mother nature hasn't given me the oportunity to try in 2 years /forums/images/graemlins/mad.gif /forums/images/graemlins/tongue.gif
/ Cheap Snow Plow #56
You could trailer to the NE and help them out. Looks like they have the perfect conditions to high center. /forums/images/graemlins/grin.gif
PJ
/ Cheap Snow Plow
got one more property, for tomorrow. it is the second passage, only 3 inches more .... thats all ... CSP did well ... one more time, everybody was amazed .
the reason is, that for part of the snow storm i was a subcontractor. at first every body laughed at the gulf cart with an extended garden tractor (ON STEROIDS) snow plow but the little beasty shut every body up after some some 18 hours of keeping the walkways clean. /forums/images/graemlins/grin.gif
/ Cheap Snow Plow
remember that i had for about 300 hours where that counter just did not work properly ... so i must be quite a bit over 1000.
Observation:running the machine that many hours in one day seems to use more oil. the first day we did not stop for eleven hours not even during refueling and the second day 4,5 and 4,5 hours. /forums/images/graemlins/blush.gif
/ Cheap Snow Plow #59
Hee hee! Sounds like a fun time on the Green Beasty. /forums/images/graemlins/smile.gif
/ Cheap Snow Plow #60
Hans,
Do you run the Rpm’s fairly high? I notice that when digging dirt I need higher Rpm’s which in turn burns more fuel. I never fill the tank completely full (7/8) but need to refuel after 4 to 5 hours of work.
PJ
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Snap-On Zeus Diagnostic Machine (A61307)
Snap-On Zeus...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
Bobcat T590 (A60462)
2019 FORD F-250XL EXTENDED CAB UTILITY TRUCK (A59823)
2019 FORD F-250XL...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
