CHEAP shade canopy
/ CHEAP shade canopy #1
Chet
Hugo, OK
Super C & Mahindra 4500 4WD
After much sweating in the sun, I decided shade would be a good thing! I just could not choke down the $300+ cost of a hard cover. Plus I wanted something easy to remove, as I have to brushhog under and around a bunch of trees on occasion. After mulling it over for awhile I decided I had enough rebar and assorted steel scraps to engineer a canopy structure. As you can see, it ain't fancy, but it cost less than ten dollars to build and it is quickly removable, due to the convenient pin locations already on the tractor. The front supports are 51 inches high from the pin to the top. The rear supports are 18 inches high from the rops pin to the top. The horizontal section from front to back is about 60 inches. The piece of notched angle across the front is 40 inches long. The shade generator is an old single fitted sheet tied on with parachute cord. Makes good shade, but structure does waggle back and forth some, depending on travelled surface. I usually just grab the horizontal peice with my free hand to settle it down. Also wrapped a peice of inner tube around the FEL hyd lines to prevent chaffing agains them. Assembly was mostly great guess work on the initial dimensions. After making the front and rear vertical members, I clamped them in place on the tractor and then welded the top horizontal member on, laid the whole thing on the shop floor, reinforced the corners and then made a duplicate for the other side. I did not go above the ROPS because it just barely fits in the tractor shed as it is. Chet PS this is a Mahindra 4500 4WD.
This shot shows the detail of the right side aft vertical attachment to the ROPS pin. It was a peice of a Snapper 30inch mower blade. One blade will make both sides.
This shot is the front right corner showing the notched end of the angle as it lays in place to keep the front uprights seperated. The angle is 40 inches long and I torched the notch about 1 inch in form each end
And finally, this shot shows the left forward upright attachment on the large loader pin. the triangle plate was a leftover from another project.
/ CHEAP shade canopy #5
<font color="blue">"As you can see, it ain't fancy, but it cost less than ten dollars to build and it is quickly removable, due to the convenient pin locations already on the tractor." </font>
Hey, it works, doesn't it??? /forums/images/graemlins/blush.gif
Plus, you can change covers depending on the season or holiday!!!! /forums/images/graemlins/grin.gif
/ CHEAP shade canopy #6
And you can Scotchgard the sheet to make it water proof. And oh yeah, you can get a set of John Deere sheets (whoops wrong brand).
/ CHEAP shade canopy #7
If your tractor was capable of being embarrased...it would be.
Green flower patterns don't match the red.
How about a red flower pattern, or a classic red and white checkerboard tablecloth, or add in some blue for a patriotic look. /forums/images/graemlins/grin.gif
/ CHEAP shade canopy #8
Does your cfo get angry when she see's you toting off her fitted sheets. I could get away with it as we have gone to a differnt size bed. /forums/images/graemlins/tongue.gif
/ CHEAP shade canopy #9
Wow, just when I thought the constant heat, sweating and possiblly developing cancerous lesions due to long hours in the sun on a tractor was bad... I saw your "canopy" /forums/images/graemlins/blush.gif
Ouch, I'll take my chances /forums/images/graemlins/smile.gif
/ CHEAP shade canopy #10
I saw a canopy like that on a jonboat last week.
LOL, I had to bite a hole in my lip to keep from laughing at them!!! I guess the fish don't mind.
KUBOTA KX057-4 EXCAVATOR (A59823)
KUBOTA KX057-4...
2017 Jacobsen 3551 HOURS (A56859)
2017 Jacobsen 3551...
2025 AGT Industrial SDA-140W (A60463)
2025 AGT...
2024 GREAT DANE FREEDOM LT FLATBED TRAILER (A59823)
2024 GREAT DANE...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2019 Bobcat MT85 (A60462)
2019 Bobcat MT85...
