Charging problem
/ Charging problem #141
Is the VR built by the same manufacture and is it the same packaging?
/ Charging problem
Greg & Keith:
1. According to my tests, the 1401 alternator puts out 30+ AC volts at the output plug; thus no rectifier.
2. The Kohler must have a built in rectifier, because I have AC going in and DC coming out.
3. The part # ST435081 is jacksmallengines.com part number, but might be the same as Kohlers.
4. Keith: The Kohler regulator looks different (smaller), and I cut the plug off the old regulator and used connectors to hook the old plug to the new regulator. That way I can always go back to a Yanmar reg. and plug it in.
It comes with instructions as to AC in, ground, DC+ out, etc.
When I get home I can take a look at the wire colors. Some of the newer Yanmar regulators have a 6 prong plug, and not 4 prong like the 1401. Two of those prongs are not used. If it stops raining, I will post a picture of it and the wiring.
Jim
/ Charging problem #143
Keith,
That Kohler regulator is not the same part as the Yanmar regulator. I'm sure it is a much simpler device, and doesn't have the 6 or whatever modes of operation the Yanmar regulator does.
/ Charging problem #144
I would be interested in seeing the schematic...
It should have at least some of the modes of the Yanmar regulator, hopefully, the ones that prevent damage to other components.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
Hay King 12' Pasture Renovator (A60462)
Hay King 12'...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
