changing hydraulic oil
/ changing hydraulic oil #1
inthe country
Rome, Ohio
Kioti CK3510
I have a Kioti ck 3510 manual transmission with a loader and backhoe. I was planning to use a non OEM fluid when replacing my transmission fluid in the future. I have always been told not to mix different brands of fluid. With this in mind, how does one drain the fluid from the attachments? Does it matter? Thanks.
/ changing hydraulic oil #2
I think the best you can do without significant work is to retract all cylinders before draining the fluid. If using compatible fluid I would not worry about it.
/ changing hydraulic oil #3
I agree. As long as the fluid is a compatible alternate. Look at your owners manual - it will tell you the grade and specification the hydraulic fluid must be.
AND - welcome to TBN and the forum.
/ changing hydraulic oil #4
Retracting the cylinders gets you the most fluid out but still has fluid behind the ram. I wouldn't worry too much about it, just get the recommended type of fluid to replace it and don't worry about it. I use the Universal hydraulic fluid from Triple S in all my tractors. It shows a long list of manufacturers that it is good for including Kubota UDT which is what my B26 calls for. I have no need for SUDT fluid here due to lack of cold during the winter. Lots of places sell a universal hydraulic fluid which is good for almost all if not all new CUT tractors.
Look for your tractors specs and get the one recommended for it because there is also some Universal Hydraulic fluid for older tractors that may be a bit too thick for the newer tractors.
The owner's manual shows several different manufactures of fluid. If I understand your replies correctly, these would be "compatible" fluids and could be mixed with the residual factory fluid. I'm usually not this **** about things, but the owner's manual leaves a lot to be desired and this is the first new tractor I've ever had. Thanks for the replies.
/ changing hydraulic oil #6
I think we can all understand/appreciate your concern regarding using the correct fluids. If the owners manual recommends a type - you can be assured it is compatible. And you certainly aren't alone in your feeling regarding the owner's manual. You will find that "interpretation" is an art.
2008 Ford E-450 Super Duty Ambulance (A61573)
2008 Ford E-450...
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
