?chains?
/ ?chains? #21
Jason,
You'll have plenty of traction up from with the FEL. If you're going to use a rear blade, that should give you additional weight on the rear along with the wheel weights. If you're going to be pushing it with the loader, add a ballast box on the 3pt with about 400 lbs in it. You'll be blasting through drifts like a red blurr.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2011 MACLTT  150 BBL ALUMINUM VACUUM TRAILER (A65643)
2011 MACLTT 150...
2017 CAT 299D2 High Flow XPS Skid Steer (A62613)
2017 CAT 299D2...
New/Unused Electric Winch (A65583)
New/Unused...
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
