Chains or Straps?
/ Chains or Straps? #1
UpstateSC_Papi
Platinum Member
Westminster, SC
Kioti CK4010
Hi all!
I am horrible when it comes to using the search function so if this has been discussed previously, PLEASE accept my apologies and point me to the right thread!
I currently haul my L2800 back and forth to our new home construction site (about 15 miles round trip). The dealer provided me with chains and come-alongs when I purchased tractor/trailer. In looking at various posts here, I see what I would call "straps" being used, that is they are not metal chains.
Do those work just as well? I have scratched up my tractor in several spots with the chains rubbing (putting them on/off) and would like to switch to the straps, but do NOT want to jeopardize myself, others and/or my equipment by doing so.
Thanks for any insight!
Michael
/ Chains or Straps? #2
let me make this short and simple. Get a length of old firehose. slip it over the chain where it touches tractor.
It is a matter of preference, legalities, and good nuff vs triple overkill.
/ Chains or Straps? #3
I use straps, easier to store, easier to work with. I only use 2, one pulling the front to the back of the trailer, and the other on the back pulling to the front of the trailer. My L still has a really strong parking brake, I also put it gear. If I have an implement I lower it all the way down.
I drive much slower when towing and watch out for that other guy.
Here is my tow from last Saturday up to Eddie's place. You can see the straps. Actually I think I moved the tractor back a bit as I was about to unload the ATV.
/ Chains or Straps?
I am all for avoiding overkill! Thanks for the idea!
Robj
You setup yours exactly as I do mine except straps vs. chains. If I decide to go to straps, suggest a good place to get them? TSC?
/ Chains or Straps? #5
Chains, at all four corners. You can use straps, but they will chafe if you aren't very careful, and when that happens, they are weakened and must be discarded.
Straps (and chains) have two ratings, SWL or safe working load, and breaking strength, which is based on average testing. Too many strap manufacturers and sellers advertise the breaking strength instead of the SWL, which is always a much lower number. Go by the SWL rating and nothing else. If the SWL isn't given or isn't clear, don't buy the strap.
In my opinion, each and every strap or chain should have a SWL rating at least as high as the load it is tieing down.
/ Chains or Straps?
Straps (and chains) have two ratings, SWL or safe working load, and breaking strength, which based on average testing. Too many strap manufacturers and sellers advertise the breaking strength instead of the SWL, which is always a much lower number. Go by the SWL rating and nothing else. If the SWL isn't given or isn't clear, don't buy the strap.
I knew absolutely none of that! I absolutely love this site and the knowledge it contains!
/ Chains or Straps? #7
Dare I say this....I think I've bought some at HD and some at Harbor Freight. They are the 2" ratchet type. They are probably 15,000 or 20,000# range. My tractor alone weighs about 2000# so one of these could yo-yo my tractor.
If I trailered my tractor every day for a business or REAL often, I would probably rig up some semi permanate cables. IE, 2 fixed lenght cables attached to the front of the trailer that I can hook to the tractor, then 2 adjustable connections in the back to draw the front ones tight. It would make things faster on the load and unload. I actually do this on my ATV when it's in the back of the truck, I have a cable attacted to the trailer hitch, it comes up between the tailgate and bed(it lives there all the time). When I load the atv I hook this into the frame, push the atv forward and lock the brakes. It keeps it about 1" from my toolbox. The atv can't move forward, I don't worry about it moving backward because I drive a big truck, not a sports car. Also no bump in the road is going to bounce a 600#atv from the bed of my truck, even still the cable goes almost straight down, not a side pull. The only way it's comming out is if I roll the truck. And a couple cheap straps isn't going to hold all the G force if my truck starts rolling.
JMO...Rob
/ Chains or Straps? #8
Fireman pat summed it up real good.
For most non comercial apps on SCUT and smallish CUT.. the straps will be fine.. as long as you have the required number, and the correct weight rating. If you were comercial and hauling under DOT scrutiny.. I'm pretty sure you will need chains at the coreners.. .. etc.
For private..whether using chains or straps.. i like 1+1/per 10' of load. IE.. minimum 2. I like to secure front and rear corners.. etc.
Fireman pat also has a good sugestion for firehose. that's what i use when hauling my parade queen tractors to a show.. keeps the chain from scraping all the perty' paint off!
soundguy
KarolinaKubota said:
Hi all!
Michael
/ Chains or Straps? #9
JMO...Rob
Sorry Rob, but this is a pretty good example of how not to approach tieing cargo down.
"They are the 2" ratchet type. They are probably 15,000 or 20,000# range. My tractor alone weighs about 2000# so one of these could yo-yo my tractor."
More likely they have a breaking strength of 10,000 lbs and safe working load of 3,300 lbs, which is typical for 2" straps. That is a lot closer to the weight of the tractor than the estimate. Plus, there is a box blade on there and fuel and lubricants, which all add up. In fact, these 2" straps appear to be just adequate for the load, if they have no fraying. They certainly aren't overkill.
It isn't safe to guess if you have the right tie down equipment. You have to know. That means knowing what your load weighs. If you have to do any guesstimating, do it on the safe side, then use tie downs adequate to the job.
You also have to know what your straps are made of. They could be either polyester, nylon, polypropylene (pray that they aren't), or something else. These materials have different characteristics, and it is important to know the difference, especially between the two most common, nylon and polyester.
Nylon is much stretchier than polyester, which means it is better at absorbing shock. However, it also stretches when it gets wet, which means nylon tiedowns tend to loosen in the rain. The longer the distance between tie down points, the worse it is. Nylon also deteriorates in the sun faster than polyester. Polypropylene is worse. It degrades rapidly from UV exposure, except for an expensive version with UV inhibitors.
I have seen tiedowns offered for sale made from all three of these materials. The norm seems to be polyester. Polypropylene tie downs are low end junk.
/ Chains or Straps? #10
Hi all!
Michael
Chains are safer than straps as they aren't as likely to break.
If you suffer strap snap and the tractor gets thrown off the trailer how bad do you reckon that would scratch up your tractor?
/ Chains or Straps? #11
Thrown off the trailer? Yall must drive a lot faster than me. I bet I'd have to take a hairpin at 50 to get mime to roll off...with no straps. And don't tell Snowridge if I take it to my BIL's house about 3 miles away, I don't even tie it down, just lock the brakes and lower the BH. Little used county road and I never get over 25-30. If I have to slam on the breaks, with a load is more of a fast slow down...I have a solid bulkhead on my trailer that'll stop it. Actually on these trips or trips down to the river bottom, about 3 miles also, I ride it up on the bulkhead.
Flame suit on!! :D:D:D
/ Chains or Straps? #12
Afternoon Michael,
I think that both straps and chains have their place in the hauling world ! I have a set of straps that I use to haul my 2 old Farmalls, these tractors dont weigh that much, the 42 A is only about 2300 lbs and the 49 Super is probablly about 2600 lbs and the straps work fine and I dont scratch the "purty red paint" as Soundguy mentions. If I was going to haul the Massey, 5000 plus I would use chains, Im not worried about scratching any paint on that tractor ! As others have said old cut up fire hose is a good way to go also. Keep in mind that if you use chain, its a good idea to stop a few minutes into your trip to retighten your binders, they can and will loosen up !
/ Chains or Straps? #13
75% of the time I use straps when pulling my enclosed trailer, it works with the rops down and everything is under cover and out of sight of sticky fingers, when using the flatbed I go "strapless" and use chain, on one end I have 10 inch J hooks, these are about 6 inches wide, tow trucks use them over axles and plases they should not, I slip some rad hose over them and they do not scratch up anything, not sure why I use both methods but chains do look more macho,
/ Chains or Straps? #14
It's not a question of how you or i drive it's the matter of the other guy.
Read Dargos thread and see what happened to him when his straps broke .
/ Chains or Straps? #15
I have an old L2350 Kubota and 2 Bobcat skid steers, I most often use grade 70 chain and ratcheting load binders. I have used 2" straps on occasion. You must be very careful about abrasion on the straps. If you do use straps, be sure to use quality ones with a high WLL. There are many cheap straps out there, avoid them!
/ Chains or Straps? #16
Here is a link to some very good and detailed information regarding the proper use of tie downs.Kinedyne, providers of high quality engineered cargo control systems.
I have used both, but the straps are certainly more convenient. Attached are pictures of the way I did it recently on an 1,100 mile round trip.
(The **small files are for those without high speed access.)
/ Chains or Straps? #18
I did actually. For those interested the link is http://www.tractorbynet.com/forums/owning-operating/53683-ratcheting-tie-downs-broke-transit.html
First, glad Dargo came out ok and no one was hurt. But his tractor weighs 7000#. Mine is about 2000#. Second is the mystery of the tractor rolling off the trailer, but not all the way, causing the trailer to start swinging which IMO caused the most pucker factor. Also with the trailer swinging wildly to the left and right, the tractor remained on the trailer. and Dargo mentioned if the tractor didn't start to exit the trailer, he might not ever known that they broke.
Everything has it's limits. As was also mentioned in the thread, you can get a super strong chain, then you could break the anchor points from the trailer, pull parts off the tractor.
Rob
/ Chains or Straps? #20
Soundguy said:
Not a question i'd like to answer on the stand.. " Um yes your honor.. the 10 minutes it would have taken me to tie that load down might have saved that pregnant mother.. " etc.
Now we are after pregnant mothers? :D I remember a recent thread where you said it was a bus load of orphans. Oh yes, bus full of orphans and nuns when the tractor trumpet broke. That's funny. :D
That's ok, flame suit still on. :D:D
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2024 Unused Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
2024 Unused Land...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
John Deere 9320 (A64911)
John Deere 9320...
