Chain lube
/ Chain lube #1
SylvainG
Platinum Member
South West, Qc
Kioti LK30
What do you use to lube the chain of your snow blower. My manual mentions nothing about this.
I'm thinking of motorcycle chain lube. Good idea? Bad? Doesn't matter?
Thanks.
/ Chain lube #4
My Lorenz manual calls for 30 weight. I put a funnel in a 1-gallon can, put a bedsheet rag over the funnel, and invert the just "emptied" oil jugs over the funnel whenever I change oil. I put those drainings in a pump oiler to lube the snowblower. The frequency of oiling is probably more important than the type of lube.
Tacky oils like some motorcycle oils, bar and chain oil, rock drill oil, to name a few, may adhere longer but also attract dust and grit. If you don't sand much for ice and snow, it shouldn't be an issue. Waxy, paraffin-like oils may not penetrate to the pins where lube is desired. On bicycle chains they are notorious for washing off in rain, and I would expect snow and ice would scour exposed snowblower chain.
/ Chain lube #6
Thanks.
Great Idea, If it last on a motorcycle it will lube on your tractor without splattering all over everything if you keep your tractor inside nice garage floor.
DevilDog
/ Chain lube #7
I use Motorcycle chan lube as well - no issues, stays on the chain - I lube after two or three storms, but in reality could most likely do it a couple of times a season as it's always looks well lubed - basically doing it for my self assurance not need.
/ Chain lube #9
I use heavy coating suffer board wax.
/ Chain lube #10
Motorcycle chain lube for me. And if I run out and use my blower I'll use chainsaw bar oil.
John Deere RO764 (A60463)
John Deere RO764...
SDlanch SDLGC80 (A60463)
SDlanch SDLGC80...
206320 (A57192)
206320 (A57192)
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A61307)
2019 Takeuchi TL8...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
Giyi GY-CWG72 Quick Attach Curved Wood Grabber (A60463)
Giyi GY-CWG72...
