Chain lube
/ Chain lube #1
SylvainG
South West, Qc
Kioti LK30
What do you use to lube the chain of your snow blower. My manual mentions nothing about this.
I'm thinking of motorcycle chain lube. Good idea? Bad? Doesn't matter?
Thanks.
/ Chain lube #4
My Lorenz manual calls for 30 weight. I put a funnel in a 1-gallon can, put a bedsheet rag over the funnel, and invert the just "emptied" oil jugs over the funnel whenever I change oil. I put those drainings in a pump oiler to lube the snowblower. The frequency of oiling is probably more important than the type of lube.
Tacky oils like some motorcycle oils, bar and chain oil, rock drill oil, to name a few, may adhere longer but also attract dust and grit. If you don't sand much for ice and snow, it shouldn't be an issue. Waxy, paraffin-like oils may not penetrate to the pins where lube is desired. On bicycle chains they are notorious for washing off in rain, and I would expect snow and ice would scour exposed snowblower chain.
/ Chain lube #6
Thanks.
Great Idea, If it last on a motorcycle it will lube on your tractor without splattering all over everything if you keep your tractor inside nice garage floor.
DevilDog
/ Chain lube #7
I use Motorcycle chan lube as well - no issues, stays on the chain - I lube after two or three storms, but in reality could most likely do it a couple of times a season as it's always looks well lubed - basically doing it for my self assurance not need.
/ Chain lube #9
I use heavy coating suffer board wax.
/ Chain lube #10
Motorcycle chain lube for me. And if I run out and use my blower I'll use chainsaw bar oil.
/ Chain lube #12
I have two motorcycles, and tries multiple chain lubes. Found plain old 80w90 gear oil works pretty stinking good.
/ Chain lube #13
If you want to hear about 1000 different options, go to any motorcycle forum and do a search on lubricating chains. About 3/4 of those options will work fine.
/ Chain lube #16
My bailers are roller chain driven and I use plain old motor oil on them, always have. I oil them when they are warm.
Now, my new round bailer has automatic chain lubing on it. Uses a pressure pump with a tank with good old motor oil in it. Has one shot greasing too.
/ Chain lube #17
I use a Loobman on my chain driven bikes. Never adjusted a chain in 7K miles on my KLR. Loobman takes, you guessed it, plain old motor oil in the supply bottle.
/ Chain lube #18
A recently deceased biker friend swore Lucas Oil Stabilizer was the best chain lube he had ever used,as he had tried them all.
He was the best all-around gear-head-bodyman I've ever met.
Lucas has preformed on my snowblower chain for 15 years with very few adjustments.
/ Chain lube #19
Might give that a try on the bike. New Round baler too.
/ Chain lube #20
Overall, I don't think it really matters as long as you keep it lubed with something. I like chain wax because it stays on a little longer.
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
2014 International WorkStar 7400 Service Truck with Crane, VIN # 1HTWGAAR1EH765285 (A61165)
2014 International...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
Club Car Utility Cart (A55851)
Club Car Utility...
