chain link fence puller
/ chain link fence puller #1
JohnnyDark
Chatham Co. NC
Farmtrac 535
this is the second one i have built for a friend of mine that does fence work
/ chain link fence puller #2
Do you think three hooks will be enough? I was planning on making something less permenant for welded wire fence. I was going to just use very long screws to clamp the welded wire fence between two 2x4's. From the top and bottom of the 2x4's I was going to run ratchet straps to the back of the tractor so I could control the tension at the top and bottom somewhat independantly. I'm looking for a less permenant solution since I don't plan on putting up lots of fence.
/ chain link fence puller #3
Here's a shot of my field fence horse wire puller. I got tired of the two by fours and bolts.
/ chain link fence puller #4
Very nice. It looks like you must put up fence often? I'm going to put it up this summer, and then again maybe 20 years from now. I suspect I can live with the 2x4's for now as all I have are two lengths of about 300', one length of 100', and, and one length of say 80'.
/ chain link fence puller #5
Wroughtn Harv - How does it grip the fence. I'm tired of 2x4's and bolts too.
/ chain link fence puller #6
Harv can't really tell from the picture, is that a rebar jig?
according to my friend it is, i haven't put up any chain link. he says he puts the metal bar thru the fence then grabs that with the hooks. i use the 2 x 4 with bolts and clamp around all the field fence i put up.
/ chain link fence puller #8
Sorta like the one pictured?
This one has done a ton of pulling fence. If you look close you'll see quarter inch lags into the wood with welded bolts so there are fewer loose parts when using.
We've got it holding up a temporary fence.
/ chain link fence puller #9
Here's another picture of it.
The two board trick works. But it takes time, bolts wear out, nuts get lost, pain in the butt.
/ chain link fence puller #10
Somewhere on TBN there's a thread with lots of pictures of the fence stretcher.
Basically it works on the friction principle. The wire is fed through the slot and around the floating rod. When tension is applied the floating rod makes the wire work against itself.
/ chain link fence puller #11
When pulling field type fencing I look to pull past the end post to keep the fabric really really tight.
/ chain link fence puller #12
If you like the stretcher you'll want to marry the fence unroller. /forums/images/graemlins/grin.gif
/ chain link fence puller #13
You can put the wire on either side of the framework.
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
50 Gallon L Shaped Fuel Tank (A64127)
50 Gallon L Shaped...
15ft. Hay Rack (A65640)
15ft. Hay Rack...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
