Chain hooks and tooth bar for RK37 bucket?
   / Chain hooks and tooth bar for RK37 bucket? #1
Ishkatan
Monrovia
RK37HC and Ford 8N
  • What kind of chain hooks work well with the RK37 bucket?
Recommended Tooth Bar for RK37 bucket? ( The web site says the bucket is 61".)
The RK37 bucket seems a bit light weight so I am wondering if a particular brand/model chain hook works really well with it or if it needs reinforcing.
I have an RK37 on order (oops, it's at the store - 3 weeks early) but noticed the bucket does not have holes for a teeth or a tooth bar. Uses:
  • - snow plowing 1-2X in winter - rarely get a lot. But it means the bar needs to come off.
  • - Moving mulch
  • - leveling an area behind the house - 0 to 3 feet deep now. 40x20 ft long. I am considering the ratchet rake vs. a bolt on tooth bar vs. temporary (2 bolts) tooth bar.
  • - moving fallen trees - plan to use the bucket to pus to side or a hook on a rope / 3/8 chain to hold in place. Hard to justify a $2,000 grapple and front hydraulics with the amount of wood work I plan on.
boat anchor hook - Walmart.com
  • - digging French drain - I have a single blade plow that really digs deep. Bucket is for moving stone to fill
  • - forest brush cleanup / trail making - no rush
Most of the time the tractor will be bush hogging and mowing.
   / Chain hooks and tooth bar for RK37 bucket? #2
If the grapple itself seems like a reach, maybe consider an add-a grapple type setup, and the front Hydraulics, you'll never regret having the hydraulic option in the front. You can have rk add the hyd and do the grapple later when $ allows. A grapple is an indispensable part of my bushogging rig.
If the bucket seems a little light for the chain hooks, frequent poster, Ken's bolt-hooks are solid and have a larger foot print than weld on hooks.
Tractor Mike has a good vid on the setup of hooks w add-a-grapple.
Given your task list, you might be happier with a root rake type grapple than the general purpose type of brush grapple rk offers.
   / Chain hooks and tooth bar for RK37 bucket? #3
I ended up looking inline for some weld on heavy duty chain eyelets, and found some. Broke out the welder and attached them myself.
   / Chain hooks and tooth bar for RK37 bucket? #4
Get the pirahna toothbar you will love it , They are hard to get but worth the wait.
   / Chain hooks and tooth bar for RK37 bucket? #5
I have D-Rings on top of the bucket, but, I also have swiveling hooks BEHIND the bucket,,
The hooks can point down, like the pic, or you can swivel them up, and run a chain over the front of the bucket.
The loader lifting power is WAY higher at a point behind the bucket, compared to in front of the bucket.
I can lift a pretty big rock, when I lift from behind the bucket,,
I could not lift that rock on the front of the bucket.
   / Chain hooks and tooth bar for RK37 bucket? #6
I like your IH 584
Pirahna toothbar is on the list. Before the Ratchet Rake and 3 point finish mower, after the hooks / attachment points. :)
I like your IH too ... and the idea of swivel hooks for front or back of bucket use. I don't weld (Do I have to learn?): so would like to go with bolt-on.
But my question though is specifically for RK37 bucket attachment hooks. I'm not sure it is sturdy enough to have a large hook in the middle of the bucket.
This thread has great ideas and input on general hooks and clevis setups.
(P.S. Is Gripon a good brand or too light?)
Bolt-On Hooks - BoltOnHooks LLC is getting some referral's here but they seem to use washers instead of a full backing plate.
   / Chain hooks and tooth bar for RK37 bucket? #8
Nothing about the Bolt-on hooks prevents you from using a back plate.
   / Chain hooks and tooth bar for RK37 bucket? #9
I just bought hooks from Bolt on Hooks a couple months ago and you can specify backing plates with them. The backing plate is the same footprint as the hook and plenty heavy. Just mount two near the loader-arm points or add another in the middle and you're set. Not worth agonizing about . . . you'll be glad you did it.
   / Chain hooks and tooth bar for RK37 bucket? #10
As you can see, I use this bucket for work. Chose to add the backplates with clevis eyes so I could hang shackles on them. Both the hooks and the shackles are VERY useful and much safer than trying to hang chain hooks on the lips of the bucket.
2016 Peterbilt 389 T/A Wet Kit Sleeper Cab Truck Tractor (A55973)
2016 Peterbilt 389...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
SKID STEER ATTACHMENT TILLER (A58216)
SKID STEER...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
2012 DIAMOND T TRAILER TRAILER (A58216)
2012 DIAMOND T...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
