Toplink CCM Toplink & QD leaks
/ CCM Toplink & QD leaks #1
n8wrl
Rural SC
Kubota L5030 HST
I seem to have this trouble with nearly every hydraulic 'project' I take on. I got a nice coat of Kubota Orange paint on the CCM toplink and hooked it up but I have leaks between the hoses and the valve, and between the hoses and the Quick Disconnect connectors. Am I supposed to use pipe dope on these kinds of connectors? Any special kind? I've read about being careful with tape, so I got a tube. With the variety of hydraulic fittings out there, I can't keep track of which need dope and which don't. Any other tips?
-Brian
/ CCM Toplink & QD leaks #2
I use a teflon paste simular to THIS on all the fittings. As you said, the tape can cause problems.
/ CCM Toplink & QD leaks #3
I don't think it is normal for any hydraulic connector to leak. Could you possibly have a burr on one of the connecting ends?
/ CCM Toplink & QD leaks #4
I also used teflon paste on my pipe thread hydraulic fittings when i hooked up my CCM HTL recently. All of my fittings leaked on the first hookup except the tapered fitting on one end of the hoses that my hyraulic hose maker told me to use nothing on :( .I cleaned them reapplied the teflon past and retightened the fittings. Since this was my first hydraulic project I was a little cautious and had not tightened them enough the first time. No leaks on the next hookup :)
By the way i painted mine black.
It is not the QD that is leaking - it is where the QD 'connects' to the hose. Mark and CCM confirmed the pipe dope too. Thanks everyone!
-Brian
Thanks for the link!
It is so hard to tell - is this stuff different from the tubes you find in the plumbing dept at Home Depot or Lowes?
/ CCM Toplink & QD leaks #7
A note: The correct fitting to use at the check valve for CCM top and side links is 3/8 BSPP to JIC or what ever you want to use. It is a staight thread and an O ring is used with the fitting. An NPTM fitting will mesh with it and works well most of the time and is always easier to find.
Vernon
/ CCM Toplink & QD leaks #8
Yes, it's different. Get the good stuff and do it once:D
As I suspected. Will do. Thanks!
-Brian
/ CCM Toplink & QD leaks #10
There was some stuff from Locktite, called Hydraulic Sealent. It was in a red tube and was liquid. I've not seen around lately, but it worked. I used to be a construction mechanic and we had to have stuff that worked. bjr
A mechannic friend of mine gave me a tube of :permatex Thread Sealant". High temp thread sealant, good to 400 deg-F and 'extreme pressures'. Has anyone head of or used this on hydraulic fittings?
-Brian
/ CCM Toplink & QD leaks #12
-Brian
Does it have Teflon in it?
According to THIS CHART, only the one with Teflon is rated for use in hydraulics. Check the product or part # on the container...
/ CCM Toplink & QD leaks #13
Gasoila is the name of the best sealant on the market guys.
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2009 Vicon 2400 9ft. 3 Point Disc Mower (A65640)
2009 Vicon 2400...
2003 MAC TRAILERS 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC TRAILERS...
2020 Case TV370B (A64126)
2020 Case TV370B...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2018 Chevrolet Tahoe SUV (A64557)
2018 Chevrolet...
