cat1 to cat2 adapter
/ cat1 to cat2 adapter #1
rustythe4x4
Sask
WHITE 700
I bought an old Ferguson cultivator not realizing my tractor was a cat2, and the cultivator was a cat1 3 point. I didnt want to hack up an antique, so I came up with this from the scrap pile:
/ cat1 to cat2 adapter #2
Looks like it should work.
Let us know if it holds up to the larger tractor pulling it.
/ cat1 to cat2 adapter #3
Man, you should have come here first! For about 5 bucks at TSC or any ag supply they have a sleve type adapter to go over the cat 1 pins to size it up to a cat 2, same goes for the top link. But what you've made looks real nice and should work fine.
/ cat1 to cat2 adapter #4
I just bought the bushings to convert cat 1 to cat 2.
$2 each from TSC yesterday.
Or you can buy cat 2 hitch pins that bolt in
place of the cat 1 hitch pins.
Pooh Bear
I can buy the bushings here for about $1.50 a set (I already have a set) but the arms wont physically fit on the cultivator, the frame is too close.
/ cat1 to cat2 adapter #6
Do they make an adapter to put category 2 implements on a category 1 tractor?
/ cat1 to cat2 adapter #7
Rusty has the correct response I believe. The bushings work to size a cat 1 pin dia. to use a quick hitch. Cat 2 arms are a wider stance and a higher top link. Will a cat 2 rear shrink in adjustment to close the difference to a cat 1 implement. Will the cat 2 components adjust to get the proper performance from a cat 1 implement? What you did looks like it will serve its purpose fine. Just thinking ? My 4420 is cat 1, so I have not encountered this issue. Gene
2019 LGMG SS1932E ELECTRIC SCISSOR LIFT (A60429)
2019 LGMG SS1932E...
UNUSED FUTURE LW45 HYD LOGGING WINCH (A60432)
UNUSED FUTURE LW45...
2014 Dodge Journey SUV (A59231)
2014 Dodge Journey...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2019 TerraGator 7300 Spinner truck (A61307)
2019 TerraGator...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
