Cat 2 Quick Hitch?
/ Cat 2 Quick Hitch? #1
cold1313
Northern, Ohio
Kubota M4D-071 Kubota F3990
What are my options for a Cat 2 quick hitch?
I have extendable lower arms to make hooking up easier and I don't change implements often but every time I do struggle with changing them...I question my decision not having one.
Can you run Cat 1 implements with the Cat 2 QH if you use the sleeves?
Or do I need special pins for all of the implements to use a QH?
/ Cat 2 Quick Hitch? #2
You can get a Land Pride's QH20 3-Point Quick-Hitch or a different brand and use the bushing on the cat 1 implements.........
/ Cat 2 Quick Hitch? #3
The Cat 2 quick hitch dimensions are different--larger. We have a MX5800 also. All of our implements/attachments are either Cat 1 or Cat1/Cat2 compatible, with the sole exception of a Kubota ballast box. That ballast box is just a little wider than a Cat 1 quick hitch will fit. We bought a Cat 1 quick hitch from Everything Attachments. It works well for everything except the ballast box but on some attachments, especially older ones, we have to use an adapter like this: Adapter Bracket Hitch 3-point Quick Adjustment Holes | Agri Supply 8717 We use that adapter for the Cat 1 brush hog, for example. (You hook the "U" end of the adapter to the top of the quick hitch by running the top link pin through both the adapter and the top of the quick hitch.) Everything Attachments also sells an adapter for use when the top link on the attachment is too high to be reached by the typical quick hitch.
/ Cat 2 Quick Hitch? #4
See the attached about dimensions (standards)of quick hitches....
Dale
/ Cat 2 Quick Hitch? #6
I just converted my Kubota L5740 to the Euro style hooks on the bottom links and love them! A quick hitch wouldn't work with many of my implements. The Euro hooks are great!! Wish I had installed years ago.
1986 Bumble Bee Fishing Boat (A66408)
1986 Bumble Bee...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
2017 International HX620 Quint Dump (A62613)
2017 International...
Pallet Racking Uprights (A62613)
Pallet Racking...
