Cast iron routing table....
/ Cast iron routing table.... #21
I use automotive wax. Seems to hold up better than regular paste wax.
Be careful there isn't any silicone in your car wax, it creates finishing headaches. That is why I switched to wood paste wax.
/ Cast iron routing table.... #22
I bought a used jointer some time back that had a lot of staining and such on the in/out-feed tables, as well I have a '48 Unisaw. Over the years I've used Boeshield and this and that special coating. The process I use to clean up and protect the cast iron today is: With my PC random orbit car polisher with a 320 disk I will spray the table with WD-40 and go to town with the polisher. I wipe the residue off and clean it really well, rags/acetone, etc. I will then use Johnson's paste wax on the table. There is no silicone in that wax so it doesn't affect the wood. With all the other crap (good expensive crap) I have used my current method has given me the best results. Years ago I had to put my equipment away and it was going to be stored in my humid basement. I knew it wouldn't do well in that environment. I had some remaining POR15 I had used on a couple cars and I painted the surfaces. It took some work to get it off, but the CI did not deteriorate.
/ Cast iron routing table.... #23
gray or maroon Scotchbrite on rust spots, then I apply paste wax with white scotchbrite and buff it out when dry with an old tshirt. I have a can of Butchers wax, as it was what 7 Corners had (sigh - I miss them...) but any normal paste wax would be fine. Same can for the last 20 yrs as i don't need to do it often. I should hit the surfaces soon before summer humidity arrives... I have T9 Boeshield too, but it appears no better or worse than wax to me.
1988 Kenworth W900 Day Cab (A62613)
1988 Kenworth W900...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
JOHN DEERE Z515E ZTRACK ZERO TURN MOWER (A65054)
JOHN DEERE Z515E...
429860 (A61166)
429860 (A61166)
2007 Down to Earth Equipment Trailer (A65563)
2007 Down to Earth...
2007 International Flatbed Dump (A62613)
2007 International...
