Case Ih C50 remote
/ Case Ih C50 remote #11
I thought you had other problems.
You probably have a piece of rubber or debris in the lands restricting movement.
One of the guys had his hyd valve load check come apart and jammed his spool. and scarred the spool which will cause him to buy a new valve.
I'm going to take it off the tractor and completely disassemble it and install new o rings
/ Case Ih C50 remote #13
I believe I would remove the spools and take a look in there and see if there is any crud, rubber, sliver of metal, etc, causing restrictions of spool movement.
2016 Texas Trailers 26ft 5 Ton T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 Texas...
Volvo L45H (A61307)
Volvo L45H (A61307)
KUBOTA RTV900 UTV (A62130)
KUBOTA RTV900 UTV...
2012 Rockwood Freedom 1640LTD 18ft. Pop Up Camper Trailer (A59231)
2012 Rockwood...
SP36 VIBRATORY TRECH GRADER (A60736)
SP36 VIBRATORY...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
