Case IH 255 Engine Stop Solenoid
/ Case IH 255 Engine Stop Solenoid #1
Norskie
SW WI
Cae IH 255
Thanks for any info provided. The 255 diesel no longer shuts off with the switch. I have to pull the engine shutoff cable. Previously I could hear the engine stop solenoid click when I turned the key on. That no longer happens. The solenoid has 12 volts on both connectors with the switch on or off. Even when disconnecting the battery and reconnecting it I don't hear the solenoid. Why is there 12 volts with the switch on or off? Does that mean the Control Timer Unit is bad? A bad solenoid wouldn't (?) explain the constant 12 volts. I am at a loss. Any help is greatly appreciated.
NOTE: Don't see how to edit. The solenoid apparently is good. If I ground the non supply side, the solenoid clicks. Does that mean the Control Timer Unit is not supplying a ground?
Found the problem was a blown fuse. The second from the left.
Asphalt Melter (A61572)
Asphalt Melter...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
2013 CORPUS 40FT T/A CONTAINER CHASSIS TRAILER (A67148)
2013 CORPUS 40FT...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
11in. Bucket with Teeth Excavator Attachment (A64194)
11in. Bucket with...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
