Case IH 255 Engine Stop Solenoid
/ Case IH 255 Engine Stop Solenoid #1
Norskie
SW WI
Cae IH 255
Thanks for any info provided. The 255 diesel no longer shuts off with the switch. I have to pull the engine shutoff cable. Previously I could hear the engine stop solenoid click when I turned the key on. That no longer happens. The solenoid has 12 volts on both connectors with the switch on or off. Even when disconnecting the battery and reconnecting it I don't hear the solenoid. Why is there 12 volts with the switch on or off? Does that mean the Control Timer Unit is bad? A bad solenoid wouldn't (?) explain the constant 12 volts. I am at a loss. Any help is greatly appreciated.
NOTE: Don't see how to edit. The solenoid apparently is good. If I ground the non supply side, the solenoid clicks. Does that mean the Control Timer Unit is not supplying a ground?
Found the problem was a blown fuse. The second from the left.
2016 MAGNUM TRAILER MLT6S (A67714)
2016 MAGNUM...
6 1/4 INCH OD 90 DEGREE ELBOWS (A67714)
6 1/4 INCH OD 90...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A61573)
2022 Mac Trailers...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
