Carrying Firewood with Compact Tractor
   / Carrying Firewood with Compact Tractor #21
   / Carrying Firewood with Compact Tractor #22
   / Carrying Firewood with Compact Tractor #23
I used to use the carry-all with the old 8N. It would hold so much, the front just bounced lightly like you see at tractor pulls. It had a receiver hitch to pull the splitter. When I got the JD with a loader, I started using a 4' x 8' trailer. With the bucket and trailer I can get much more wood to the shed per load.
   / Carrying Firewood with Compact Tractor #24
I built a bunch of these crates to stack all my fire wood in. Now your wood stack comes to the source. Stack it once and done
Jay
   / Carrying Firewood with Compact Tractor #25
Can you use your 3pt and chain to skid a few good size trees at a time across your pasture then cut and split back home?
   / Carrying Firewood with Compact Tractor #26
my dad put a 4 foot piece of plywood in his bucket and chained the front outside corners to the tow hooks on top of his bucket for his MF as a bucket extender. he is able to carry quite a bit this way.
I built a 4 foot wide by one row worth by 5 foot high carryall out of scrap t posts and c channel for my tractor. later i welded a 1 1/4 hitch tube under carry all for a cheap tow option for my splitter or trailer at the same time.
they both works for our needs. you should be able to figure something that works for you
   / Carrying Firewood with Compact Tractor #27
IBC totes are invaluable on my farm. Google the images for ibc tote firewood.
   / Carrying Firewood with Compact Tractor #29
Farm hay wagon can make tight turns, or make a single axle trailer with the axle mid-wheelbase. wherever tractor goes, the trailer will follow.
THIS IS EXACTLY WHAT I WAS THINKING EXCEPT I WOULD USE A STEEL PALLET!!!
Mini Skid-Steer Land Leveler (New/Unused) (A59225)
Mini Skid-Steer...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
New/Unused CFG Industrial MH12RX Mini Excavator (A57453)
New/Unused CFG...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2014 JLG 6042 TELESCOPIC FORKLIFT (A52709)
2014 JLG 6042...
2012 BIG TEX PIPE TRAILER (A58214)
2012 BIG TEX PIPE...
