Carrying a Pole Saw
/ Carrying a Pole Saw #1
ns_in_tex
Platinum Member
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
Thank you richh, I used your idea to carry my chain saw.
Still needed a way to carry my pole saw, which I use more than chain saw, unless logging.
Now can carry both at same time.
Following attachments show the outcome.
Look at 6th attachment (ready to go to work) first to see finished product, then look at first 5 attachements to see details if interested.
Attached is front pole bracket
Rear saw bracket
with latching pin
saw latched in
front pole latched in
ready to go to work
hope this helps others as much as it helps me.
/ Carrying a Pole Saw #7
What kind of saw is that? It looks like you have to keep the FEL down so that it doesn't hit the front of the saw -- is that right?
The saw is a Stihl HT 70, see attached.
The saw needs to be mounted 2" forward from where I have it to be able to raise loader to top heighth without the saw hitting the cab. If no cab, no problem I think.
So I don't have to worry about hitting anything except tree limbs with the front, if I am pulling up brush with the tree getter. I do normally set it off after arriving to job site, while working the brush with the loader.
I think you will like it.
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
2007 INTERNATIONAL 7600 6X4 T/A VACCUUM TRUCK (A66091)
2007 INTERNATIONAL...
2013 GMC Sierra 4x4 (A62613)
2013 GMC Sierra...
ATS 13,000lb Electric Winch (A62679)
ATS 13,000lb...
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2006 Hypac C530AH Pneumatic Wheel Compactor (A64553)
2006 Hypac C530AH...
