Carrying a Pole Saw
/ Carrying a Pole Saw #1
ns_in_tex
Platinum Member
East Texas
Kubota L4610 HSTC, International 2400, Hesston 1280,
Thank you richh, I used your idea to carry my chain saw.
Still needed a way to carry my pole saw, which I use more than chain saw, unless logging.
Now can carry both at same time.
Following attachments show the outcome.
Look at 6th attachment (ready to go to work) first to see finished product, then look at first 5 attachements to see details if interested.
Attached is front pole bracket
Rear saw bracket
with latching pin
saw latched in
front pole latched in
ready to go to work
hope this helps others as much as it helps me.
/ Carrying a Pole Saw #7
What kind of saw is that? It looks like you have to keep the FEL down so that it doesn't hit the front of the saw -- is that right?
The saw is a Stihl HT 70, see attached.
The saw needs to be mounted 2" forward from where I have it to be able to raise loader to top heighth without the saw hitting the cab. If no cab, no problem I think.
So I don't have to worry about hitting anything except tree limbs with the front, if I am pulling up brush with the tree getter. I do normally set it off after arriving to job site, while working the brush with the loader.
I think you will like it.
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2019 ALLMAND LIGHT PLANT (A65643)
2019 ALLMAND LIGHT...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
100-gallon L-shaped Portable Fuel Tank (A66408)
100-gallon...
