carry all
/ carry all #2
I thought the same way. I ended up buying the TSC frame and am not sorry I did. It will take the thousand pounds OK but if you load it up that heavy or heavier don't hit any big bumps. All those G's can bend a lift pin. I had 1/3 cord of hardwood firewood on, so way over loaded, and tweaked a pin slightly. Just straightened and reinforced the angle a little.
gg
/ carry all #4
I made a toolbar that I can put a lot of different things on including forks that allow me to pick up pallets of different configurations depending on what i am doing. I also use them to carry logs.
My toolbar holds discs for hilling the garden. With the forks I pick up a little boom sprayer. very handy - I appreciate the adjustability of the forks and more strength which you do not get with the County Line version.
/ carry all #5
I purchased one of these locally a few years ago for little over a hundred bucks, maybe 115. It gives you a great foundation to build on. They aren't meant to be pallet forks. It is steel with plenty of holes for you to build a wooden or metal box and attach to it. There are extensive photos of individual carryalls that posters have shared on this web site. If you wanted to weld on it and make a steel tray you could do that too. You can't go wrong with this for a start.
/ carry all #6
/ carry all #7
Who here has made their own carry all? I am thinking of building one myself but its hard to beat this one for 130 bucks.
CountyLine Carry All - For Life Out Here
Here's a good time for me to ask this question: Does anyone see a price for the carry all, after clicking on the link? I haven't been able to see prices at the TS site for a long time. Maybe it's my computer.
/ carry all #9
I found an old one at a farm auction for $5! Threw away the rotted wood, painted the frame & built one to use on tractor drives: 2785.jpg Sold it after I quit the drives.
/ carry all #10
Picked mine up from TSC for a bit less after discount coupon. Well worth buying one. I used mine as the base for a wood box that I reinforced to mainly carry firewood. Adding casters makes it much easier to move around when not on the tractor. Once finished, I plan to add some pvc pipes to hold tools etc.. Good Luck.DSCN0758.jpg
/ carry all #11
Pricing won't show unless you add your zip code to the My TSC Store link at the every top left of the page. Your cookies probably got cleared so you need to reset your location.
/ carry all #12
I had one, but thought it too flimsy, so welded it into the frame for my 3-pt hitch sprayer. Replaced with a 3-pt pallet fork (bale mover would do, too) which is all-welded and much sturdier. Easy to slide under pallets holding different loads (firewood, rocks, etc.) for instant carryall, no unloading and reloading. Plus, I just chain the pallet fork onto my bucket with a couple of short chains and a load binder for nearly instant pallet fork on the front.
2019 BOBCAT E26 EXCAVATOR (A63276)
2019 BOBCAT E26...
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
2022 EZ-GO ELITE...
2015 FORD F350 XL SUPER DUTY BUCKET TRUCK (A63276)
2015 FORD F350 XL...
2011 Chevrolet Express 2500 Cargo Van (A64556)
2011 Chevrolet...
