carb trouble???
/ carb trouble??? #21
have you tried running with gas cap loose? if cap vent is plugged, engine will eventually starve for fuel.
/ carb trouble??? #22
Yes...thanks...but tried that...same problem.
I am now thinking contaminated fuel..or a bad SAM.
Ignition control module.
Any one with experience of failing electronics ?
Pete
/ carb trouble??? #23
Gotta be a carb problem.... ordered a rebuild kit today....which is just
gaskets, float needle , and 4 top screws...good thing ...
(I lost one in the intake valley ) .... and a new idle screw and spring....
pretty lame rebuild kit actually.
The things I Do know are :
1. Fuel IS getting to carb
2. Fuel is NOT contaminated
3. Carb runs lean , and stalls
Things I don't know :
1. Is ignition cutting out ?
Spark is there when tested
2. Is SAM at fault here ?
3. Can coils go bad under load ?
Some one out there must have had a dupe problem like mine....
wish I could find them
/ carb trouble???
i kept getting trash in mine...i strain my gas out of the can now....i tried to clean out the tank but its a difficult shape to clean out......someone else was saying that it happens a lot to these carbs but i dont know
/ carb trouble??? #25
Is your tractor actually runable now ?
Mine is not.... but thank God we are in a dry spell and grass is not growing.
Hope to have this problem licked by the weekend.
I am wondering if there is a carb out there that can be substituted
for this Keihin ?
/ carb trouble???
mine is runnable as of when i parked it. I had finally finishe the lawn. I started it to move it yesterday and it was fine, but didnt move far
/ carb trouble??? #27
Sounds like mine WAS....now it will barely run...
can't wait to put the rebuild kit in ...later this week.
If that don't do it.... may be time to torch it !
/ carb trouble???
let me know how it works with the carb kit
/ carb trouble??? #29
Got it today... will try to install tomorrow.
Not much to it .... all rubber gaskets and seals , and it looks like
and adjustable needle .... I guess I may have to drill out plugs to side ports ?
Anyone know ?
/ carb trouble???
GTSrider did u rebuild the carb? and if so how does it run now? thanks Don
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
2001 FORD F-750 SUPER DUTY (INOPERABLE) (A58214)
2001 FORD F-750...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
INGERSOLL RAND  G25 GENERATOR (A60736)
INGERSOLL RAND...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
43024 (A59228)
43024 (A59228)
