Carb problems
/ Carb problems #1
ldabe
SE, Michigan
PT-422 2002 Robin eng.
Hey guys,
I need some help on what the problem is with my PT.
When I start it up (with full choke, and 1/2 throttle) it starts fine.
Then I back off the choke as anyone normally would.
I take the throttle up all the way to full speed.
From here everything is going good (sitting and running this way or working it under loads).
Here is the problem...
when I back the throttle back down to slow (say to get off to pick up some trash or a stick, but leaving it running) then when I get back on to throttle back up to full, the engine starts 'popping' real bad!
I cleaned the air filter, and the plugs were fine.
I repeated the same proceedure above after letting it set awhile, but this time I left the air filter and cover off to be able to see what was going on in the Carb.
When it was 'popping' I could see fire inside the Carb.
Does anyone have any suggestions as to why this would be doing this, and of course what the remedy might be?
I didn't take it out of the garage after checking it with the air filter and cover off. I was afraid it could die on me out in the field, or even worse ruin the engine.
Thanks in advance for any comments, suggestions, or remedies.
Abe.
/ Carb problems #2
A grim possibility is a broken or sticking intake valve. To check that, removed the valve covers (after disconnecting the fuel line) and crank the engine WITH THE SPARK PLUG WIRED DISCONNECTED OR THE PLUGS REMOVED to see that all four rockers arms and valves move correctly.
BUT FIRST! - -
It's more likely that the carburetor float is sticking. I had the same thing happen two different times (PT-425 w/Kohler engine, 500+ hours).
The first time the plugs were very wet; I removed them, let them dry, cranked the engine while the plugs were out (blowing some unvaporized fuel out), reinstalled, and managed to get the PT started after WAY too much cranking. It worked fine for about two days.
Then, it quit again with much popping and carrying on, and I was out in the woods where there was no possibility of towing the machine back.
So, I removed the air filter entirely, including the bottom plate which is attached to the carb by four bolts.
Then, I removed the top of the carburetor (after carefully cleaning everything as well as can be done in the woods). If you do this, be careful when detaching the linkage by rotating the carb top various directions to get it off the cable end.
Obviously, be very careful to not lose the needle valve or clip.
The float level appeared to be OK, as did the needle valve and seat, BUT, there was quite a bit of debris in the bottom of the float bowl. I emptied the fuel from the bowl (sort of mopped it out with clean rags), and carefully cleaned out the debris. I'm not sure how it got in there, as I have always used a good fuel filter, but apparently some can get through, or was already in there when I bought the PT new.
After reassembling everything, the tractor started easily and has run perfectly for the last 20 hours.
The first symptoms of the problem were the occasional popping, hard starting, and inability to idle at anything less than 1/2 throttle.
If your PT has a Robin rather than a Kohler engine, I assume that the procedure would be similar.
Hope this helps.
Regards,
Mark H.
/ Carb problems #3
I had a similar problem. I removed the carb and removed a bunch of crap from where the fuel goes into float valve. While i was at it, i cleaned out the gunk in the bottom of the bowl.
/ Carb problems
Thanks guys!
I will try to take it apart and clean it up, and hopefully all will be well.
I will let you know when I finish.
Thanks again,
Abe.
/ Carb problems
Well, it looks like I will have to try checking the valves :~(
I cleaned the carb with no success. It really looked pretty clean anyway.
But, I went ahead and cleaned it, but it is still "popping".
It might be a few days before I can check the valves...so if anybody else has anything to add, please do.
Thanks.
/ Carb problems #6
I had a similar problem on a 25 hp Kohler engine, I fixed my problem by cleaning out the fuel shut off solenoid. It should be on the bottom of the carb bowl.
/ Carb problems #7
Thanks.
Last fall my 18 hp Robin was running pretty rough, so per J.J.’s suggestion I cleaned the fuel shut off solenoid. Made a big difference. Engine runs much smoother now. You may want to at least give it a try before moving on. :eek:
/ Carb problems
Thanks JJ & Barryh,
I will try cleaning out the fuel shut off solenoid as suggested.
Probably will not get to it until this weekend, to many other irons in the fire for Thursday and Friday.
Thanks again, and if anyone has anything else, please jump right in.
/ Carb problems
Thought I would bring this up to date.
I was drowning in other projects/businesses (that bring in money) so I figured I would just take it in and let someone else who has the time/place/tools and knowledge to work on this.
I went to the Robin site to find someone to service the engine in my area...8 miles down the road...so far so good.
Service man said approx. $200 to find/fix the popping problem, change eng. oil, hydro oil, hydro oil tank gasket, fix a broken zerk fitting. I supplied the eng. oil filter & hydro oil filter.
One full month later (after 3-4 calls...part on back order...ignition coil) and $400 dollars above the quote, I have the PT-422 back.
Labor: $180
Material: $413.56
Tax: 24.81
Total: 618.37
Majority of price for parts/material was for 2 ignition coils at $116.88 each.
There was a few other material/parts not mentioned that came to approx. $35-40 bucks (no big deal).
The 1 month wait, was what bothered me the most.
The parts/materials I can understand.
But now...
I was not able to use it for about a week went brought home because of other priorities.
So I went out today to do some much needed mowing. Hooked up the deck and let the grass fly for about 25-35 minutes, with an outside temp of approx. 92 degrees, and humidity at approx. 85.
I looked over my shoulder and notice the hydro cooler fan was not operating!
Headed back to garage, turned off engine and let cool down for about 30 min.
Went out to see if I could find problem after looking at PT's "Power Trac Wiring Diagram".
The diagram has a wire going from the cooler fan to a cooler fan "thermal relay" connection. Then on the other side it has another connection that is 'suppose' to have a wire (white) what looks like a harness (SO #14-5).
I don't have any wire connected to this other side of the "thermal relay" and don't remember if there was one (don't see any wire hanging with that type of connector) before I took it in for service.
SOS ... need help!
Anybody understand this mess, or have any suggestions? Please ;~)
Thanks in advance,
Abe.
Edit: 'suppose' to have a wire (white) what looks like a harness (SO #14-5).
Should be: wire (white) what looks like it goes to a harness (SO #14-5).
/ Carb problems #10
Abe, I looked at my unit and this white wire goes into a cable harness which was lying against the left hand side of the engine compartment. It is almost straight to the left from the "thermal relay. It looks like it's inside a tygon (clear plastic) tube. The cable harness is hiden under the lip of the engine compartment. You can reach under that lip and find it, if your unit is just like mine. There is a big piece of heat shrink around the cable there and the white wire comes out of the heat shrink tube, runs forward a few inches, and then backward and up to the "thermal relay". If this does not help I can take a picture.
/ Carb problems #11
Labor: $180
Material: $413.56
Tax: 24.81
Total: 618.37
But now...
SOS ... need help!
Thanks in advance,
Abe.
Did you check the fuse for the fan, When I first got my 425 the fuse blowed. I put the next size larger fuse in it, the wire going to the fan fuse was tight and had a loose connection at the fuse. Fixed that and haven't had any more problems since.
/ Carb problems
Bob,
I am going to try and take a pic also to post very soon, I am not sure if I am explaining it right.
Toy,
Yes, I did check the fuse, there is an inline 10 just before the "thermal relay".
Thanks for the input, if you (or anyone) thinks of anything else, or has any other suggestings please feel free to jump right in.
Btw, what did you think of the price(s) for service, and the wait?
Thanks again everybody,
Abe.
/ Carb problems #13
ldabe said:
Bob,
Toy,
Abe.
Prices seem kinda of high, but what do I know, I do the work myself. The wait was too long.
You are missing a wire on the thermal switch, right?
/ Carb problems #14
Abe,
I also think the cost was excessive. Sounds like they kept replacing parts until it sort of ran good. Did they ever explain what the problem was, and did you get your old parts back. Do you know if they actually did what they said they did? You could have bought a new carb for that price. I doubt if it was the valves. Sounds like a fuel problem. I wonder if they checked the fuel pressure? How about debris in the tank. Someone else had a problem with trash and plastic pieces in the tank clogging the flow. They changed out the coils for what reason. I think they took advantage of you in time and money.
/ Carb problems
J_J said:
Abe,
JJ, no I did not get the old parts (my mistake) and I agree with you that I don't believe it was the valves either. When the service guy first listened to the popping, he mentioned something about a "key", I think he called it a "weaver key" but don't quote me on that.
As for the coils, the way I understood it, one was bad (and I thought that was what was causing the popping...but I may have misunderstood) and the other coil was changed since they were already changing the one, they would not have take the engine back out if the other happened to go bad a little down the road (thats the way I understood there reasoning).
I am still confused about the fan not running, and only one wire to the "thermal relay".
I am going to try and attached some pics of the "thermal relay" and the "wiring diagram".
Thanks again guys.
/ Carb problems
Thanks again guys.
Here are the pics (I hope):
/ Carb problems
Ok guys, where are ya at?
Can anyone tell me if they have two wires (one on each side / terminal) of the "thermal relay" that tells the oil cooler fan to come on? (If you look at the wire diagram, it looks like to me that there should be two wires, one on each terminal, one that comes from the fan and then on the other side one that goes to??? ... I am guessing to a power source.)
There are other wires not connected to anything, but none has the femal connector that makes connection with the terminal on the relay.
Also, if the "thermal relay" is possibly bad (I take it that it is just a heat sensor) can I take off the wire coming from the fan, and splice/connect/jumper to another source wire to get the fan running...and if so, what wire would you suggest?
Thanks in advance for all responses.
Btw, what does 'SO #14-5' mean on the wire diagram?
/ Carb problems #18
I don't have your tractor, but based on your picture and your wiring diagram you do not have a wire running to something. Because of the fuse placement (it should be between the battery and the relay) it looks like the wire to the fan is gone. A simple fix I am sure.
Do you have a volt meter? You can double check your relay is working by warming the PT up and placing one meter probe on the relay and another on a ground. Should give you 12 volts when warm (none when cold).
I am a bit more concerned that you said there are a bunch of wires not running anywhere. Again, using your volt meter and setting it to ready ohms (or circuit if it is a good meter) you should be able to quickly track down the wires form what they came from.
Wiring is pretty simple on these (actually kinda more complicated than they should be, but still quite simple).
I would track back the wires from the fan. It may be one of those not connected (or both, one should be ground and one should be hot).
Carl
/ Carb problems #19
OK... re-read your post. The idea of a thermal relay is nice because engines and hydraulics like a particular temperature. If you live in a cold weather state you do not want your fan to come on too soon. If your relay is shot, (I said above that how to check it - Take a volt meter and test the side with the fuse (red lead of meter on connector, black lead on a good ground or the metal of the tractor without paint on it). If you have 12 volts with the key on check the other side of the relay the same way with the engine off - cold - it should read 0 volts. then run the tractor and warm it up, check the other side of the relay the same way and see if you have 12 (12 to 15 volts) on that side. This shows that the relay is working (there are other ways but this a simple way for beginners).
If you do, then the relay is good.
Next, follow the wires back from your fan. One wire should be attached to the a common ground (screwed to the metal of the tractor somewhere). The other wire should be heading to the relay. I am not sure why your wiring is funky (it looks like someone has played with it as you have the fuse in line where your wiring diagram says there is not one) but whatever. Hook it to the relay.
One other thing is that the hot wire from the ignition switch could be the disconnected one. Maybe someone bypassed your relay already.
Finally, of course you do not need the relay, but I would suggest a switch for the reasons above. The thermal relay just makes the whole cooling process a bit more idiot proof. If you live in a warm weather area then you could wire the fan directly to the ignition switch (actually, I would use a relay which I can describe to you how to do) Using a relay will prevent too many amps from going through your ignition switch an wearing it out prematurely.
We can discuss this here if you want or you can private IM me...
Carl
/ Carb problems
Carl
Carl,
There are two wires coming from the fan, one goes to the fuse, and then continues to the relay. The other one goes to a bolt on the tractor for ground.
As for checking the relay using an ohm meter, shouldn't I go across the terminals of the relay (when cold shouldn't have anything) and then when hot I would have a change.
Does this sound anywhere close, or am I missing your point all together?
Ok, JUST SAW your second post, and I am going to go try some of your suggestion.
I will be back in a while. Hopefully ;~)
