Cape Cod Barn
/ Cape Cod Barn
Picture of the first course of roof panels going on. They were low enough that we could get them up onto the roof with the job site forklift. And then screw them to the rafters and purlins with 10" screws. Panels are 5 1/2" of foam with 1/2" OSB on each side. Should provide pretty good insulation this winter.
/ Cape Cod Barn
Had to rent a crane for the rest of the roof panels because of the height. Here's the crane in action from a distance.
/ Cape Cod Barn
Second course of roof panels going on, with assistance of the crane. You'll notice how the outside edges have been routed out to accept a 2x6 for edge framing.
/ Cape Cod Barn
With this side of roof panels on, it's time to install the 2x6 edge framing. Also helps lock and align the adjacent panels on the gable end. Note the clever little work platform on the site fork lift.
/ Cape Cod Barn
Here's a photo of the barn with all the wall and roof panels finally put on.
/ Cape Cod Barn
Now that all the panels are on, it's time to tackle a few touch up tasks. One of the joist beams for the loft floor was cut incorrectly, so here it is being recut and the mortices finished off by hand.
/ Cape Cod Barn #147
bebster; Beautiful building. That has to be a dream come true. You guys even used fall arrest, and that's a good thing.
The tree on the lookout really shows your pride. It's well deserved /forums/images/graemlins/cool.gif /forums/images/graemlins/laugh.gif
/ Cape Cod Barn #148
Absolutely beautiful work and it is such a pleasure to see your PROJECT!!
Dean
PS makes my little addition look puny but it was just a one man project!
My little barn
/ Cape Cod Barn #149
Thanks for keeping up the post on this. It is beautiful and will be for a very long time. You are doing the land a favor.
Keep us posted.
Cliff
/ Cape Cod Barn #150
Okay bebster, clue us in to the final exterior look. Vinyl? Wood? Masonary? Combination?
When you post them scenic from a distance pictures it takes my breath away.
You've done good.
/ Cape Cod Barn #151
bebster, I noticed a few pieces of waste SIPS on the ground. Did you cut out the windows on site or have them precut according to your plan? The SIP distributor to whom I was talking said it would be more economical to cut them ourselves -- I think he mentioned something like $35 per cut to have the factory do it. He had a nifty attachment for a skill saw on display; looked like a small chain saw, and was designed to cut the OSB and foam.
Same question for the angles under the gable ends -- pre-cut at the factory or did you do it?
I guess what impresses me the most is that you essentially have TWO structural processes -- the SIPS are structural in and of themselves, and you have them mounted on a structural timber frame. I guess that thing's not going anywhere soon...
/ Cape Cod Barn
The final exterior will be pre-dipped white cedar shingles. Pre-dipped to make them look a little weathered and gray as well as to preserve them better (and no need to paint). The trim is cedar that has been pre-stained with preservative before applying. I'm hoping to avoid painting this thing during my lifetime! Hopefully we get it done before the cold weather sets in.
The SIPs were originally planned to be factory cut, but they screwed up and were late. So I had them shipped on site uncut. We proceeded to cut them for window/door openings, but that wasn't too bad at all. BUT, you need to route out around the openings 1 1/2" so a 2x4 can be nailed in to provide a frame for the windows to nail to. This routing is the worst job I've ever seen! The panel company sells a grinder with a paddle like blade the routes out the foam, but it gets everywhere! It will be a year before I can get it all out of the bushes, etc. It will be short money to have it done in the factory, and I'd have it done that way again if I had the time.
But you can't beat the structural integrity of the timber frame plus the SIPs. I'm figuring this barn will be here for a few centuries at least. My house is 200 years old, and not anywhere near as well constructed.
Glad you all enjoy the photos. More to come...
/ Cape Cod Barn #153
<font color="blue">BUT, you need to route out around the openings 1 1/2" so a 2x4 can be nailed in to provide a frame for the windows to nail to. </font>
In some of the pictures I've seen of various SIP installations, it looks like they are using an electrically heated wire gadget to cut the foam. It looked a large cheese grater set to cut at the proper depth. Or, maybe I imagined such a gadget and will have to invent it?
/ Cape Cod Barn #154
</font><font color="blue" class="small">( Glad you all enjoy the photos. More to come...)</font>
We got you now. We're going to be just like the kiddos. "YOU PROMISED!!!" /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Cape Cod Barn #155
</font><font color="blue" class="small">( It looked a large cheese grater set to cut at the proper depth. Or, maybe I imagined such a gadget and will have to invent it?)</font>
I think I've seen "hot knives" like you're describing on tv shows where they're sculpting foam. You know, like for that fake stucco (EFIS) finish.
/ Cape Cod Barn
A few more photos.... This one is of the roof with "ice and water" shield applied all over it. Finally no water coming through the roof and it stays dry inside.
/ Cape Cod Barn
Next went on Typar "house wrap" to keep the walls dry. Once this was on we were able to pop the windows in.
/ Cape Cod Barn
Needed to put in a retaining wall because the grade drops down from the main floor level to the drive out garage level. The excavators used their machine to build a wall out of boulders. The operator would pickup a big rock with the bucket and thumb like you and I would a 5 lb one, spin it around and set it in place.
/ Cape Cod Barn
Placing the boulder onto the NE corner wall...
/ Cape Cod Barn
NE corner boulder retaining wall completed. Took less than a day. Very cost effective and the look goes great I think with the barn.
2012 TURNKEY INDUSTRIES 29DT DATA TRAILER (A67714)
2012 TURNKEY...
Delta BS100 Shopmaster Bandsaw (A64553)
Delta BS100...
2017 HINO 195 4X2 S/A  16FT BOX TRUCK (A69167)
2017 HINO 195 4X2...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
JOHN DEERE 325G SKIDSTEER (A67714)
JOHN DEERE 325G...
2017 VERMEER TG7000 TUB GRINDER (A66091)
2017 VERMEER...
