Can't view just "Other Forums"
/ Can't view just "Other Forums" #11
jmurray01
With all due respects,
Just curious why you have to spread your signature all over the page. Sure take up a lot of space and nothing is really said.
Do you really need to be recognized that much.
Must be your screen size. It doesn't show up like that for me.
/ Can't view just "Other Forums" #12
I think he is talking about when you put the pointer on the "forums" tab there use to be a drop down of all the forums and you could choose a specific one. Now the dropdown window does not come up. I noticed the same thing.
/ Can't view just "Other Forums" #14
Signatures can be turned off:
MY HOME
General Settings
Visible Post Elements
Show Signatures (uncheck)
Save Changes
/ Can't view just "Other Forums" #15
Old forum, if you hovered over the FORUMS, a drop-down list would appear, from which you could select the forum you wanted to view.
Now you must select FORUM, which brings up a page with all the forums on it, you must scroll down to the forum you want to view, and select it.
/ Can't view just "Other Forums" #16
Yes, it is true that you can turn the signatures off, but the large white space is still there and is wasted space.
As in this post.
Confused, are you trying to see the posts in all of the "other forums" subforums at the same time, or just see the list of "Other Forums"?
If it is the latter, they can be seen at: Other Forums
Aaron Z
Nope, it brings me to the main forum.
As for my signature, I've never had any other complaints about it...
/ Can't view just "Other Forums" #18
As in this post.
An alternative is to use the Ignore List:
MY HOME
Edit Ignore List
Type User Name
Click Okay
Save Changes
INSPECTION (A61166)
INSPECTION (A61166)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
JOHN DEERE 50G EXCAVATOR (A62129)
JOHN DEERE 50G...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2004 Mack CV713 Granite Fuel and Lube Truck (A59230)
2004 Mack CV713...
