Can't Make Up my Mind - Help
/ Can't Make Up my Mind - Help #1
Tractor_Jim_CT
Connecticut
BX23
Can\'t Make Up my Mind - Help
Need to grade driveway including potholes, level and clean up cleared property. Do I want a box blade or do I want a landscape rake. Dealer said landscape rake and boxblade will not did into a packed down dirt/gravel driveway with the BX23. Do I need both?
I have quotes for Woods and Landpride with Woods being much less. Is Woods a better quality.
/ Can't Make Up my Mind - Help #2
Re: Can\'t Make Up my Mind - Help
If you have a BX23 I would use the FEL and a boxblade to work the driveway, just make sure you dig out enough around the current potholes, smooth the dirt back out and compact the dirt as you put it back, or the pothole will likely reappear very soon.
/ Can't Make Up my Mind - Help #3
Why decide? Just get both! You know you're going to need them both eventually anyway. /forums/images/graemlins/smile.gif
/ Can't Make Up my Mind - Help #4
Personally I find myself using my rear blade 95% of the time to level dirt , move snow, dress up my gravel driveway, etc. The landscape rake is very cumbersome and tends to dig into the dirt and gravel too much.
/ Can't Make Up my Mind - Help #5
The boxblade seems to work the best for me. I maintain a 1/2 mile private gravel road with a 72" boxblade.
The most difficult challenge is the potholes. I find you have to open up the surface of the road to the depth of the pothole to eliminate them. If you don't get down that far, you will simply be filling in the pothole with loose material that can wash back out the next time it rains, and the pothole reappears. So we rip open the top 2-3" of the road in the area around each pothole and then grade it smooth.
Timing and the composition of the road are critical. If it's too dry, it can be pretty hard to dig into the hard pack. If it rains before traffic has a chance to re-pack all the loose material, it can make a mess. The more gravel and less dirt at the surface, the better.
With a BX-size tractor, you will be limited by the weight of the box blade, so these timing and material issues will be even more important. Get the heaviest 4 ft. box blade you can buy for best results.
2019 John Deere R-4038 (A61306)
2019 John Deere...
(6) 10R22.5 TIRES & RIMS (A63745)
(6) 10R22.5 TIRES...
John Deere 50 (A60462)
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
2021 John Deere 5230L Applicator (A63109)
2021 John Deere...
Ingersoll Rand 185 Compressor (A64047)
Ingersoll Rand 185...
