Can't keep it up
/ Can't keep it up #1
neilly2
Bucks County PA
Kubota L285 with V1500A engine
Can\'t keep it up
My three point lift raises fine, and stays raised until I let go of the control lever. Then the lever moves forward and the 3pt. comes down. This has been going on for months now and I can't figure it. Nothing leaking, and the up pressure hasn't changed.
Worse of all, I wouldn't trust my local tractor guy with hydraulics if my life depended on it and the nearest hydraulic shop is a couple 100 miles away.
Any ideas would be appreciated.
/ Can't keep it up #2
Re: Can\'t keep it up
Possibly if you were to fill out the bio, someone might be able to help resolve this for you. Immediate information needed would be year, make, and model of tractor. Hours of use might also be helpful. If you put in your city and state, you never know when another TBN'r might come over to help resolve the problem if he is close. Sorry about more questions than answers, but without more of the facts, no one can help. /forums/images/graemlins/frown.gif
/ Can't keep it up #4
Welcome to TBN, /forums/images/graemlins/cool.gif
Like Junkman was saying, we have to have more information to help.
/ Can't keep it up #5
Find out what's supposed to hold the control lever in position, probably a mechanical friction washer.
/ Can't keep it up #6
Depends on if your tractor has position control, draft control, or just up or down, no real position control.
If a typical position control, you might just need to tighten ever so slightly a big nut on the friction washer at the bottom of the lever, but we need to know the tractor you have.
--->Paul
/ Can't keep it up
Don't know why but about 4 messages have dissappeared from this thread. In one I said I filled out my member info, but for ease I have a Kubota L298.
/ Can't keep it up #8
When a post is removed.......any replies to it will disappear as well.
/ Can't keep it up #9
I thought he wanted to know about Viagra or something. I was going to say you were on the wrong website. as far as the 3pt. I haven't a clue.
120 GALLON WATER TANK (A62131)
120 GALLON WATER...
2002 BMW 325Ci Convertible Coupe (A61569)
2002 BMW 325Ci...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
2007 Ford F750 Dump (A62613)
2007 Ford F750...
2016 CATERPILLAR 930M WHEEL LOADER (A62129)
2016 CATERPILLAR...
Auger Bit Mini Skid Steer Attachment (A61567)
Auger Bit Mini...
