Can't just retube that
/ Can't just retube that #1
fatjay
Elite Member
Eastern PA
Not enough
Rust will just cut up the new tube. I think i want to take the tire off and weld a new piece of metal in then cut a hole for the stem. I think i'll clean up the rest of the wheel while I'm at it.
Yes steiner has a new one for $100, but I think i'll try this first.
/ Can't just retube that #4
What's the challenge in that?
Also when done, I would apply a little body putty and paint for a smooth wheel/tube interface.
/ Can't just retube that #7
Wire wheel and some JB Weld will take care of that.
/ Can't just retube that #8
I've thought about welding a repair on a rim. Keep in mind chasing rust holes are always a hassle.
The one suggestion, however...
The new valve hole doesn't have to be in the same place as the old hole. If you have a clean part on the rim on the opposite side, drill there.
Went through hell getting the tire off, but I got it off. Wire wheel'd the whole thing. All the metal is in good shape, it's just that spot. I think water got in through the valve stem and just rotted that specific spot.
/ Can't just retube that #10
Repaired a few antique wheels and always mindful of the application…
Anything above a farm plow speed and on the highway must be robust so as not to leave you stranded or worse.
/ Can't just retube that #11
Several years ago, there was an antique auto race in MN (think 1910s). A person was killed when turning a corner at speed (20mph?) when a wood spoke wheel 9that looked perfectly good) broke, and the car rolled. They changed the rules after that.
That said, I don't think the OP has enough runway on his property to reach a dangerous speed.
It'll be sturdy when I'm done with it. And I don't take it for more than a mile down the road.
Also I don't do anything "at speed" as the brakes consist of dropping the bucket.
/ Can't just retube that #14
You are anything but boring :)
/ Can't just retube that #16
What's your hourly rate on that job? :p If you're having fun, go for it, I've certainly done worse myself.
Then again, if you have easy access to a used replacement for @CH4Ohio's claimed $30...
I looked around, didn't see anything local, only shipped. $100 is a pretty good deal for what it is, but it's more of a figuring it out thing. Never changed a tire on a wheel before. It kinda sucks without the right tools.
/ Can't just retube that #18
You can pick up a nice cheap set of tire irons on Amazon, which help enormously for getting the tire off of or on to the rim. Use your loader bucket or a bottle jack under a vehicle to break the bead, and the rope tournequit trick for re-seating the bead. Lots of farmers have found lots of ways to make this job more do-able without having to visit a tire machine.
/ Can't just retube that #19
We would put a plank at the edge of the rim, and drive up on it to break the bead
/ Can't just retube that #20
Nice! I put the edge of my loader bucket on a block of wood placed on the sidwall near the bead, and just press down. Same idea. Others put the tire under a vehicle, with a jack between the sidewall of the tire and the frame of the vehicle.
It doesn't take a ton of force, probably just a few hundred pounds, but it's more than you'll want to do without some leverage.
2025 CFG Industrial NT20-CZ Mini Excavator (A59228)
2025 CFG...
2020 Ram 3500 4x4 Ext. Cab Pickup Truck (A59230)
2020 Ram 3500 4x4...
24in Digging Tooth Bucket Excavator Attachment (A60352)
24in Digging Tooth...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A60352)
2019 Allmand...
4ft Mini Skid Quick Attach Rotary Cutter (A61306)
4ft Mini Skid...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A61307)
2024 Kubota...
