Can't just retube that
/ Can't just retube that #1
fatjay
Elite Member
Eastern PA
Not enough
Rust will just cut up the new tube. I think i want to take the tire off and weld a new piece of metal in then cut a hole for the stem. I think i'll clean up the rest of the wheel while I'm at it.
Yes steiner has a new one for $100, but I think i'll try this first.
/ Can't just retube that #4
What's the challenge in that?
Also when done, I would apply a little body putty and paint for a smooth wheel/tube interface.
/ Can't just retube that #7
Wire wheel and some JB Weld will take care of that.
/ Can't just retube that #8
I've thought about welding a repair on a rim. Keep in mind chasing rust holes are always a hassle.
The one suggestion, however...
The new valve hole doesn't have to be in the same place as the old hole. If you have a clean part on the rim on the opposite side, drill there.
Went through hell getting the tire off, but I got it off. Wire wheel'd the whole thing. All the metal is in good shape, it's just that spot. I think water got in through the valve stem and just rotted that specific spot.
/ Can't just retube that #10
Repaired a few antique wheels and always mindful of the application…
Anything above a farm plow speed and on the highway must be robust so as not to leave you stranded or worse.
It'll be sturdy when I'm done with it. And I don't take it for more than a mile down the road.
Also I don't do anything "at speed" as the brakes consist of dropping the bucket.
/ Can't just retube that #14
You are anything but boring :)
/ Can't just retube that #16
What's your hourly rate on that job? :p If you're having fun, go for it, I've certainly done worse myself.
Then again, if you have easy access to a used replacement for @CH4Ohio's claimed $30...
I looked around, didn't see anything local, only shipped. $100 is a pretty good deal for what it is, but it's more of a figuring it out thing. Never changed a tire on a wheel before. It kinda sucks without the right tools.
/ Can't just retube that #18
You can pick up a nice cheap set of tire irons on Amazon, which help enormously for getting the tire off of or on to the rim. Use your loader bucket or a bottle jack under a vehicle to break the bead, and the rope tournequit trick for re-seating the bead. Lots of farmers have found lots of ways to make this job more do-able without having to visit a tire machine.
/ Can't just retube that #19
We would put a plank at the edge of the rim, and drive up on it to break the bead
/ Can't just retube that #20
Nice! I put the edge of my loader bucket on a block of wood placed on the sidwall near the bead, and just press down. Same idea. Others put the tire under a vehicle, with a jack between the sidewall of the tire and the frame of the vehicle.
It doesn't take a ton of force, probably just a few hundred pounds, but it's more than you'll want to do without some leverage.
2012 MULTIQUIP DCA-7OU512 TOWABLE GENERATOR (A63276)
2012 MULTIQUIP...
2018 Ford F-250 4x4 Ext. Cab Pickup Truck (A64194)
2018 Ford F-250...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
Wooden Glider Chair (A64557)
Wooden Glider...
JOHN DEERE 5075M TRACTOR (A63291)
JOHN DEERE 5075M...
2018 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 KENWORTH T680...
