Can you adjust the air pressure on filled rears (BX25D)
   / Can you adjust the air pressure on filled rears (BX25D) #1
Mowbizz
Platinum Member
Lakes Region, NH
'14 Kubota BX25D
Wondering if there's enough room to let a little air out for mowing? I have a bumpy lawn and the seat bottoms out under my hefty weight. Never had any experience with filled tires except knowing I have them...:D
   / Can you adjust the air pressure on filled rears (BX25D) #2
Put the valve stems uppermost, then just bleed out air. The tires should not be more than about 3/4 full. If any liquid is expelled, rinse it off.
Viola!
   / Can you adjust the air pressure on filled rears (BX25D) #3
I run a lower air pressure for mowing. If I have something on the 3PH I raise the pressure on the rear tires.
   / Can you adjust the air pressure on filled rears (BX25D) #4
You should be able to let the pressure down. We are often in the ten lb range in the rears.
   / Can you adjust the air pressure on filled rears (BX25D) #5
I have 16psi in the front and 11.5 in the rear. The tires have a nice flat contact patch. I've been experimenting with the tire pressures for the best ride when mowing. I still may change them some more. I also use 3 weights on the front for mowing.
And your rears are filled?
   / Can you adjust the air pressure on filled rears (BX25D) #9
Cool...will be adjusting before the next mowing! Thanks!
I think they still need some adjustment but it is better than what Kubota recommends.
2015 Kia Cadenza Sedan (A50324)
2015 Kia Cadenza...
2006 Volvo VNM Truck, VIN # 4V4M19GF26N396168 (A51572)
2006 Volvo VNM...
2008 BMW 535xi AWD Sedan (A50324)
2008 BMW 535xi AWD...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
Case 586G (A50120)
Case 586G (A50120)
2007 JLG SkyTrak 10042 10,000lbs 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
