Can you adjust the air pressure on filled rears (BX25D)
   / Can you adjust the air pressure on filled rears (BX25D) #1
Mowbizz
Lakes Region, NH
'14 Kubota BX25D
Wondering if there's enough room to let a little air out for mowing? I have a bumpy lawn and the seat bottoms out under my hefty weight. Never had any experience with filled tires except knowing I have them...:D
   / Can you adjust the air pressure on filled rears (BX25D) #2
Put the valve stems uppermost, then just bleed out air. The tires should not be more than about 3/4 full. If any liquid is expelled, rinse it off.
Viola!
   / Can you adjust the air pressure on filled rears (BX25D) #3
I run a lower air pressure for mowing. If I have something on the 3PH I raise the pressure on the rear tires.
   / Can you adjust the air pressure on filled rears (BX25D) #4
You should be able to let the pressure down. We are often in the ten lb range in the rears.
   / Can you adjust the air pressure on filled rears (BX25D) #5
I have 16psi in the front and 11.5 in the rear. The tires have a nice flat contact patch. I've been experimenting with the tire pressures for the best ride when mowing. I still may change them some more. I also use 3 weights on the front for mowing.
And your rears are filled?
   / Can you adjust the air pressure on filled rears (BX25D) #9
Cool...will be adjusting before the next mowing! Thanks!
I think they still need some adjustment but it is better than what Kubota recommends.
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
2025 REDEDLIFT CPD25-XD4 FORKLIFT (A51222)
2025 REDEDLIFT...
Bush Hog 10 ft. Rotary Cutter (A50860)
Bush Hog 10 ft...
2006 John Deere 650J LGP Crawler Tractor Dozer (A50322)
2006 John Deere...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
