Can you adjust the air pressure on filled rears (BX25D)
   / Can you adjust the air pressure on filled rears (BX25D) #1
Mowbizz
Lakes Region, NH
'14 Kubota BX25D
Wondering if there's enough room to let a little air out for mowing? I have a bumpy lawn and the seat bottoms out under my hefty weight. Never had any experience with filled tires except knowing I have them...:D
   / Can you adjust the air pressure on filled rears (BX25D) #2
Put the valve stems uppermost, then just bleed out air. The tires should not be more than about 3/4 full. If any liquid is expelled, rinse it off.
Viola!
   / Can you adjust the air pressure on filled rears (BX25D) #3
I run a lower air pressure for mowing. If I have something on the 3PH I raise the pressure on the rear tires.
   / Can you adjust the air pressure on filled rears (BX25D) #4
You should be able to let the pressure down. We are often in the ten lb range in the rears.
   / Can you adjust the air pressure on filled rears (BX25D) #5
I have 16psi in the front and 11.5 in the rear. The tires have a nice flat contact patch. I've been experimenting with the tire pressures for the best ride when mowing. I still may change them some more. I also use 3 weights on the front for mowing.
And your rears are filled?
   / Can you adjust the air pressure on filled rears (BX25D) #9
Cool...will be adjusting before the next mowing! Thanks!
I think they still need some adjustment but it is better than what Kubota recommends.
2021 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A50323)
2021 Toyota Tacoma...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A51222)
2015 INTERNATIONAL...
International 4700 Vibra Tiller (A51039)
International 4700...
2021 ALLMAND BROS, INC. NIGHT LITE TOWER (A50854)
2021 ALLMAND BROS...
2021 Kubota SVL97-2HC Compact Track Loader (A50657)
2021 Kubota...
