can it be welded, or do i buy new muffler.?
   / can it be welded, or do i buy new muffler.? #1
jwjsr
ALA
ford 4000
All I have is a bernzomatic and propane or Map gas cylinders??
   / can it be welded, or do i buy new muffler.? #2
From the looks of the rust in the second pic I doubt you could get the metal clean enough to weld it. Think its time for a new one.
You know a good source for kohler Command v twin 27 hp mufflers?
   / can it be welded, or do i buy new muffler.? #4
Have it brazed.
i had someone put i new engine in about 7 years ago and they didn't put the heat thingy back on and resulted in the heat frying the choke and throttle cables. Now when the muffler busted it burned the wiring harness, but not enough to short anything,
   / can it be welded, or do i buy new muffler.? #7
Make a tinplate cap that fits over the hole and pop rivet it into place. Seal it with lots black silicone and paint it black. Ive repaired a couple of mufflers this way. Its easy and if you do it neatly they look as good as new. (I do have a welder, but trying to weld thin, rusty metal like this is too hard.)
Probably what I would do in this case is use the existing cap and pop rivet some tabs to it that can then be pop rivetted to the side of the muffler.
   / can it be welded, or do i buy new muffler.? #9
i don't see good weldable or brazeable material there. I think i'd go the pop rivit route. use soem of that strapping tape. or cut strips from roof tin.. etc.. drill locations. rivit and forget about it..
   / can it be welded, or do i buy new muffler.? #10
It might get too hot for brazing and that's only if you got ALL the rust off first.
Bobcat 3560 Skidloader Breaker (A50774)
Bobcat 3560...
Year: 2008 (miles exempt on title) Make: Nissan Model: Sentra Vehicle Type: Passenger Car Mileage: (A51694)
Year: 2008 (miles...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
