Roberts2600
I'm going to start off with yep I did a dumb thing and now I may need my tractor to get me out of a jam. So I was moving my RV around with my truck (2015 GMC Sierra) in my yard to get it to its new resting home and out of the low spot. It had rained several days earlier but I believed the ground was dry enough to move it to the new spot up a slight incline without issue. Well, it made it about 3/4 of the way before it started spinning the truck tires, not AT tires, in the grass and dirt. I did not bury the truck or anything crazy but did get things a little out of line with the back end of the truck trying to slide around. I decided to stop and wait a few more days before attempting to move the RV again and left the truck and RV connected. I am now debating if I should try again with the truck or if should I get the Mahindra 1626 out and connect it to the RV and move it the last 100 feet up an incline. Or do I need to phone a friend and connect the tractor to the truck? So my questions are:
1. Can the Mahindra 1626 pull an RV safely?
2. Is there a risk of too much weight on the back of the tractor causing it to go ass-over-tea-kettle?
3. Can the standard steel bar for connecting a ball hitch support the load? (The one Mahindra hides under the seat.)
4. Are there other concerns I haven't thought of yet?
5. Other ideas or suggestions?
Camper Details
Dry Weight: 6,427 lbs.
GVWR: 7,740 lbs.
Hitch Weight: 740 lbs.
**Update I don't have a 3-point ball hitch. I just have a short drawbar that came with the tractor**
Camper Details
GVWR: 7,740 lbs.
