Camp property found, now updates.
/ Camp property found, now updates. #701
Now wait a cotton picking second, you can bad mouth a YouTube channel, or the Jackery and similar, but you dont get away with bad mouthing Honda. :)
Snow drift but 4100+ hrs on this old 6k Honda gx powered gen set. All original only reason I took possession of it from my old employer before it went to scrap yard cuz it burns oil and no longer ran for a full day without adding oil. Low oil shutoff device. Anyways I can still run my smaller welders off it. And I plugged in the house for a day during a power outage. Always Starts in a couple pulls despite sitting for extended periods, after I removed in tank fuel filter and put a inline one on instead.
/ Camp property found, now updates. #702
Our place has evolved over time, with increasing utility. Each major step in improvements has opened up broader use. I’ll outline them to show at least one set of steps.
The house is old - 1799 - but was never modernized and utilities never brought it. In 1985 it was essentially the same as it was in 1799. With no running water and no flush toilet, use was limited to a few days before you really wanted a shower badly, and only hardy guests would go.
In ‘85 we put in a gravity feed dug well and a septic system, plus a propane water heater. Then a regular bathroom. New also wired the house because we had all the walls open to insulate, but all you would do was plug it into a portable generator. This transformed the place completely, and made it accommodating for anyone, and you could stay as long as you wanted. Heat was via a wood stove only, and the road was not plowed. We designed the plumbing carefully so you just needed to open a couple of valves and everything drained so it wouldn’t freeze.
In 2000 we took another big step and installed central heat via propane, and put in a small solar+battery system to run the furnace circulator and to have lights. Refrigeration was all propane. We also hired a neighbor to keep the road plowed. With this, the place was usable year round, and you could just roll in at any time because we kept the heat at 55 when not there. We also added a full laundry, making it a fully functional house.
Since then we have made further improvements and expanded to include a full shop. One big step was a major fix up on the road, filling soft spots with rip rap and then covering the whole road in hardpack. Prior to this, the place was inaccessible during mud season.
Now we live there full time. It’s still off grid, but we barely think about power.
Somewhere in this spectrum I’m sure you will find what fits your needs and goals.
BADA$$!!! Living the dream!!!!
/ Camp property found, now updates. #703
WOW! This is the first time that I looked at the location on Google. 80 acres surrounded by that much state land. Hunters dream!! I know you don't hunt, but trail makers/maintainers dream too! I know technically you legally are probably not allowed to make trails on state land, but that doesn't mean you are not allowed to clean and maintain existing trails. Look at all of those logging roads on the sat image! No one cares if you clean them up and ski all over that in the winter!
Very cool!! How close is the nearest neighbors? Miles?
/ Camp property found, now updates. #704
Lots of good advice here - maybe more than ArlyA is ready for at the moment. He is a pretty thoughtful guy, and will probably put together a pretty good plan, once he's had a chance to take in what he's got. For a while he'll probably get by just fine with a CanAM 6x6, a cordless drill and a Stihl pole saw ;)
WOW! This is the first time that I looked at the location on Google. 80 acres surrounded by that much state land. Hunters dream!! I know you don't hunt, but trail makers/maintainers dream too! I know technically you legally are probably not allowed to make trails on state land, but that doesn't mean you are not allowed to clean and maintain existing trails. Look at all of those logging roads on the sat image! No one cares if you clean them up and ski all over that in the winter!View attachment 4112173 Very cool!! How close is the nearest neighbors? Miles?
We are not sure how close the nearest neighbor is but there is another camp north towards Covington and just off the highway. Maybe 1.5 miles away? Its driveway looks unused.....
/ Camp property found, now updates. #706
I don’t understand what either of those things mean. Can you elaborate?
Just below the topsoil is solid rock. The only way to drill a well would be, well, a well drilling rig that can dig through rock down to a water source.
In some areas, there is no rock just below the topsoil. You can pound a sand point by hand down pretty far to reach a water source.
A sand point is a pointed perforated section of pipe. You put a cap on it that's made to take hammer blows, and you pound it into the ground. Remove the cap, add a section of pipe, replace the driving cap and repeat.
Here's a kit. There are many videos on youtube showing how it's done.
/ Camp property found, now updates. #707
Well, the area is very wet, and if you can find a seem going 15-20 ft down, as remote as it is; water May be good. Even if bad, it can be pumped to a tank, and chlorinated, or used for house hold tasks, showers, ect; just not drinking. Might also be some springs or seeps around; depending on the topography.
It's one think to bring a weeks worth of drinking water; but another to bring a weeks worth of All water. Being very careful with water, thats still 50 gal of general water per weeks stay, plus drinking.
/ Camp property found, now updates. #708
I was just answering the person's question regarding a sand point and why it won't go through rock.
The OP says the property is all rock underneath, so I'll take his word for it.
/ Camp property found, now updates. #709
Wonder if you can find a spring somewhere close to your new place develop it a little and use it for a water source? Who knows it might end up being the purest best tasting water in the area.
/ Camp property found, now updates. #710
Oh, don’t get me going on that Honda generator…..
/ Camp property found, now updates. #711
Thanks. We have very thin soil too, then you hit granite. Most areas the soil is 2-3’, but no more. Our well is very shallow - literally 2 tiles so 4’ total, and usually has about 2’ of water in it. It’s right on a spring so replenishes fine except in droughts like we have now. I’ve been away for 2 weeks, but expect to return to no water. Not looking forward to that. Fortunately I have a drill rig coming this week or next to drill a deep well.
The folks who owned it (and still do, really) did so as a hunting camp. He is pretty elderly now and not sure when was the last time he hunted there. The son we meet says the drive is to long. Nonetheless, if we can improve the road out there and the logging trails on the property, maybe it will become more valuable to whoever we sell it to. We also hope to spent lots or time there starting this winter. If our weekend is dry, we'll be out there over the weekend!
/ Camp property found, now updates. #714
On water, I would consider a Kelly well; typically about a 3 ft diameter whole, maybe 8 ft deep, you place a 15-18" ABS/HDPE with slots cut every inch or so, and wrapped in a filter fabric, into the hole, and then back fill the hole around the pipe with a #57 type stone. Water comes out "clean" but not potable.
/ Camp property found, now updates. #715
Arly, hope your hiking around this weekend takes you up onto the big ridge on the southern end of your acreage. Who knows how accurate the google map topography is, but looks like it could be at least an 80-100' vertical, maybe some really cool rock cliffs and outcroppings?
/ Camp property found, now updates. #716
@ArlyA before you head out there for the weekend, I suggest you look at the property on Google Earth, not Google Maps. Google earth will allow you to see elevations across the property by moving the cursor. Your camp is at about 1646' elevation. It looks like your elevations goes from a high of about 1675 to a low if about 1620.
Another cool feature of Google Earth is that you can look back in time at earlier satellite images to see how the property has changed over the years.
If you are not familiar with Google Earth, you can download it for free onto your computer. I use it very often to measure property size and distances. It is pretty accurate. At least it is accurate around here on flat land. Not sure how accurate it is in hills.
/ Camp property found, now updates. #717
Ever hear of or use a composting toilet? I think they have evolved somewhat over the years. If my septic failed inspection up there I was considering one at least temporary. Til I either saved the funds to hire or find the time and attempt to build a new Septic system myself. Unfortunately with so much rock over there I doubt you'd pass a perk test.
Lots of Maine camps use composting toilets, and yes I believe that they've come a long way. Along with that LP refrigerator. LED lightning has also been huge for off grid use.
We have been on the southern end and these photos were taken there. Problem is with all the rain we've seen here this summer, the logging trail to the south is almost better with a canoe now! He hauled the materials to build two blinds down there on this route (just one shown) in dryer times.
We already use google earth.
/ Camp property found, now updates. #720
Yeah, between solar/battery technology, LED lighting, 12v coolers/refrigeration, 12v accessories like fans, propane on-demand hot water heaters, diesel heaters, internet hotspots, composting toilets, etc. It has never been easier to live off grid. One can make a VERY comfortable existence in the bush and it doesn't have to break the bank. It is almost like cheating! I am starting to outfit my little off grid container cabin for more comfortable living as I have a buddy staying there. It has been fun to research and design these systems.
78in Bucket Skid Steer Attachment (A59228)
78in Bucket Skid...
GIYI SF60-60" HYD SIDE SHIFT FORKS (A60430)
GIYI SF60-60" HYD...
Le Roi 80-Gallon Air Compressor, 220 Volts (A59076)
Le Roi 80-Gallon...
Margaritaville Miniature Decorative Truck (A59231)
Margaritaville...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
RING 2 STARTS HERE @ 9:15 AM (A60430)
RING 2 STARTS HERE...
