Cabin Heat Question
/ Cabin Heat Question #21
sadly my Toolcat is not the Kubota engine and last time I spoke with the dealer nothing was available they suggest keeping it indoors
Have you ever pulled the heater out to see if it even works? I can feel the engine near the heater and it does warm a bit. Here is your thread from 2 years ago:
Toolcat block heater
/ Cabin Heat Question #22
hi ruffdog, yes even pulled the heater it works as designed, unlike a wet blockheater that is surrounded by coolant the dry one sits in air and relies on convection to transfer the heat to the coolant, its just not efficent at cooler temeratures
/ Cabin Heat Question #23
I do understand the issue, I have always thought that this heater did not work as efficiently as the freeze plug heater in my tractor. You also get much colder than I do too.
Years ago we would install circulating tank type heaters on medium duty trucks. You can get them 1000-2000 watts and will circulate the warm coolant through the block. Here is a video of a guy putting one on a big deere.
/ Cabin Heat Question #24
The Loggers around here use to use Quick Couplers, to circulate coolant from the vehicle they drove to work.
Worked good except Old Coolant from 1 would get transferred to the other 1. 5-10 minutes of idling time and the Skidders would be warmed up in -35F
/ Cabin Heat Question #25
I just went out to see where I would mount a tank type heater. Everything is so crammed tight that it is hard to see, let alone be able to work on it. (ten pounds of beans in a one pound can) Just trying to find a coolant port on the block is hard and I didn't see one yet. I checked the manual for the port to drain the block of coolant. You remove the hose going to the oil cooler right below the engine oil filter.
/ Cabin Heat Question #26
couple years ago picked up a Wabasto coolant heater to install, looked all around and just no room to mount it, ruffdog, if you figure where to mount one I would be interested in a few pictures how you squeezed it in
years ago on my series A removed the seat and cover figured I could mount one in line with the heater hoses, good luck be hard to put a beer can in there yet alone a 2 liter bottle size heater
Since I won't have mine delivered until next week, I don't have one to look at but I was wondering if the chamber the new style heater mounts in is completely sealed, and if so, why couldn't you fill it with coolant and install a long reach freeze plug style heater. It would definitely transfer heat better.
/ Cabin Heat Question #28
The cavity is a precision blind hole bored into the side of the block. The heater slides in with very little clearance so it must be clean. Bobcat says to install dry and not to use grease etc in the pocket. I have seen silicone high temp heat transfer compound and I wondered if it would help/hurt the install. I installed mine dry. Here is a video that shows the install.
Yes, I've watched the video before and that's why I question if it's a self-contained or blind bored hole just the size of the heating element or does it open up past the bore? I can't tell from the video.
/ Cabin Heat Question #30
Yes, I've watched the video before and that's why I question if it's a self-contained or blind void chamber, why couldn't one fill it with coolant and install a long element freeze plug style heater. It would probably be more efficient for transferring heat, as well as fluid being a better heat sink than air.
Your heater size would still be small and after the heater to fluid to surrounding metal heat transfer is complete, you are still just heating the same area. An element that is sticking inside a water jacket can heat all the coolant in the block which amounts to a larger area. Either way, most small block heaters are 400 watts and can only do so much. You would think by now all manufactures would have better dedicated ports that would support sufficient heaters for very cold climates.
KJ K1119 11'x19' Carport (A60463)
KJ K1119 11'x19'...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
LAYMOR BOOM SM300 (A60736)
LAYMOR BOOM SM300...
2013 Felling Trailers T/A Side Dump Flatbed Trailer (A56857)
2013 Felling...
Club Car (A59231)
Club Car (A59231)
