Cab light
/ Cab light #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
I am looking to upgrade my cab lights on my 5100M to LED. What is everyone using, to keep it factory looking? I've only found Larsen Lights
/ Cab light #3
I'm retired - no good reason for doing anything at night. However - if I did - I would be getting a single LED marine flood light from J A McDermott Corp - 1639 Stephen St - Ridgewood, NY. I've seen what one of their 50 watt, LED flood lights can do. Commercial fishing boats will usually have two or four mounted on the roof of the cabin.
If you TRULY want to see what is out there - this one light will do the trick. No fooling around - dead serious.
/ Cab light #4
Two lights will reduce the shadows, and important if working with the lights, either from behind or in front. Interested a bit in the result of the question.
/ Cab light #5
I'm running 4 Rigid D-Series Pro with a driving lens pattern off the front of my 4520. They turn night into day. Don't buy cheap LED unless you like to replace them often. Been there done that. There are several good brands out there but hey are not cheap.
D-Series - D-Series PRO | Rigid Industries
Cat CB24B (A60462)
Cat CB24B (A60462)
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59912)
2019 ISUZU NPR 4X2...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A62129)
2007 CATERPILLAR...
