Cab light
/ Cab light #1
OrangeToys
Platinum Member
SW Missouri
2016 Kubota M7060HDC
I am looking to upgrade my cab lights on my 5100M to LED. What is everyone using, to keep it factory looking? I've only found Larsen Lights
/ Cab light #3
I'm retired - no good reason for doing anything at night. However - if I did - I would be getting a single LED marine flood light from J A McDermott Corp - 1639 Stephen St - Ridgewood, NY. I've seen what one of their 50 watt, LED flood lights can do. Commercial fishing boats will usually have two or four mounted on the roof of the cabin.
If you TRULY want to see what is out there - this one light will do the trick. No fooling around - dead serious.
/ Cab light #4
Two lights will reduce the shadows, and important if working with the lights, either from behind or in front. Interested a bit in the result of the question.
/ Cab light #5
I'm running 4 Rigid D-Series Pro with a driving lens pattern off the front of my 4520. They turn night into day. Don't buy cheap LED unless you like to replace them often. Been there done that. There are several good brands out there but hey are not cheap.
D-Series - D-Series PRO | Rigid Industries
Attention (A57148)
Attention (A57148)
2004 Chevrolet Silverado 1500 4x4 Pickup Truck (A61573)
2004 Chevrolet...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
2005 John Deere 6x5 Rotary Mower Tractor Attachment (A61572)
2005 John Deere...
Kubota V1505-T Turbo Diesel Industrial Engine  Pump Takeout (A63689)
Kubota V1505-T...
