Cab for the Kubota
/ Cab for the Kubota
Added the linear actuator to raise/lower the chute, and power window motor to turn it left/right today.
Power snowblower chute test - YouTube
Yeah I hear you guys are getting something good. Here we still have nothing. Little brushing last thursday, but nothing since then.
/ Cab for the Kubota #84
It seems like all the snow we missed out on Dec/Jan arrived the last 2 weeks.
Once again, I'm glad it missed me(sort of). I broke the steering shaft trying to turn the wheels on asphault while stationary with the blower up. I'm making a power steering system for it now.
/ Cab for the Kubota #86
Ouch. Power steering is a worthy add-on.
Sadly there's no factory options available. Existed at one time, but no longer. Same with aftermarket. I have a JD 322 hydro steering box on the way, will make a custom mount for it, plumb it into the factory power steering block on the tractor, and weld up a mount for a cylinder to attach to the frame.
I fixed my shaft, but it's still a real bear to turn the wheels when moving, let alone not, so power steering is a desirable feature for me. Still, I'm treading new territory and figuring it out as I go. Cab is pretty much done, just need the door windows, but I don't think we're going to have any snow this year, so that really isn't a priority. The cab will come off for the summer and it will pull a 60" mower behind it, so I'll need steering regardless.
/ Cab for the Kubota #88
I realize that, did you see the link in my signature? :D
Too bad the guy that sold me mine is no longer selling them but there are other ways to make it happen.
Yup, I have to figure something out and fast, seems like spring is just around the corner.
Resurecting this thread, progress has been made.
Starting off, the power steering. Got a hydraulic power steering off a john deere 318, cylinder off surplus center.
Mounting brackets made, custom hoses made.
Cylinder mounted and hoses run. Everything works perfectly.
Used it all summer to cut grass with a 60" rear finishing deck. Was annoying, picked up a matching zero turn for $500 with a bad hydro and rebuilt it.
Now stocked up on diesel fuel with electric pump, 14' hose, and nozzle.
Now that the battery is not easily accessible, I added a jump point under the hood.
Time for hydraulics to raise/lower the snowblower. Right fender seemed like a prime location.
More custom hoses set me back $400 and the wife didn't talk to me for 2 days.
Can't reverse because the new hydraulic lines off the hydraulic block. Fixed.
That brings us to present day. Took the blade back to clear some brush. 4wd worked great. Honestly couldn't be happier.
7' back blade doesn't fit in the garage without turning it. Also doesn't raise high enough. Also only clear front door by about 2" when up against the wall.
Overall I have about 6k in this project, have learned a lot of useful skills, and learned a lot about my machine. At the point where if I can picture it in my head, I can build it, and that's a good place to be.
/ Cab for the Kubota #91
Nice, looks good. Power steering is a huge plus.
Is that jump point left bare? If so how about a rubber hose boot to go over it? I can see a wrench landing on that thing, seems stuff like that becomes a magnet for tools. :D
Do you have a thread on the hydro rebuild on the Zero Turn?
/ Cab for the Kubota #92
How long until you add a front end loader...and then backhoe?
Looks like you already have the brush cleared for the new dog house ;)
/ Cab for the Kubota #93
Looks good fatjay, a project to be proud of for sure! :thumbsup:
Where did you buy the orbital valve and how much if you don't mind sharing?
Thanks,
Dave
Thanks,
Dave
Ebay, $40 + 12.40 shipping.
hydraulic valve log splitter | eBay
One port seems to have a slow leak, I'm going to try tightening it a bit more, I don't want to break it though. It's a very slow leak and only when the blower is up.
Kubota hydro rebuild. Learned a lot with this one. http://www.tractorbynet.com/forums/parts-repairs/384864-kubota-zd21-hydro-rebuild.html?highlight=
The jump point normally has a little rubber boot, it was just off for the picture. And I needed to jump it, left the ignition on by mistake. That's when I added it.
/ Cab for the Kubota #96
Keep in mind that valve isn't designed for power beyond. Don't dead end the 3 point or any downstream valves too often ;)
I did once or twice before I got used to it. It turns really fast, but now that I'm used to it hasn't happened since. Still, it works extremely well.
Finally put the windows in and plumbed the heater core. Put a trailer light connector at the snowblower for easy disconnect of the wires. Started it and ran it for about 20 minutes, turned on the heater, and no heat. Reluctantly i grabbed the brass fittings, which should have been hot to the touch, but they were cold. I have to check to make sure the water is flowing, if the water pump is working. I have no idea. When I cut the bypass hose water came out, so it should be working. I'll disconnect a hose and crank it and see if any water comes out.
/ Cab for the Kubota #99
Your heater is mounted pretty high. I've only installed a couple heaters and they were mounted low in the cab below the top of the radiator so you could work the bubbles out.
To stand any chance of flowing water to your heater core, first try with the heater sitting on the ground so you can get all the air out of the system. Even then, it probably won't work very well being up that high.
/ Cab for the Kubota #100
SUPER NICE !! great job! Those B Kubotas will last forever, you will never wear it out.
PALLET OF STAINLESS STEEL FEEDERS & WATERERS (A64278)
PALLET OF...
Bigfoot (A64557)
Bigfoot (A64557)
Wagon Wheel Chair (A64557)
Wagon Wheel Chair...
2022 EZ-GO ELITE...
Wooden Glider Chair (A64557)
Wooden Glider...
2025 Rippa IREAS Ripper Mini Excavator Attachment (A64553)
2025 Rippa IREAS...
