Cab for B7800
/ Cab for B7800 #1
DHD
Platinum Member
Maine
Kubota B7800
I am thinking of getting a soft sided cab for my B7800 and I was hoping you folks might provide me with some answers
to some questions I've got.
1. How much additional height would I be gaining above the ROPS? I have a height issue getting in and out of my garage.
2. My RM snowblower has a hand crank to rotate the discharge chute. Do cabs have rear panels so that I could access the hand crank?
3. Which cabs are better?
I've heard of Sims and Curtis cabs, are there other brand names?
4. I was thinking of installing it myself or would that be best left for the Kubota dealer?
Thanks
/ Cab for B7800 #2
Hey,
I don't know what a soft side is but here is what I did to keep the sun off. I build a top made of Ash and 1/2" ply.
I just bolted (used big hose clamps) 1x6 ash boards that went about 1" above my ROPS, I made a lap joint to the next boards that go over your head and towards the front of the tractor. I screwed on the plywood and let it overhand a good bit. Painted it all black. Will try and post a pic. bw
/ Cab for B7800 #3
I have a Curtis soft cab on my 2910. It is actually about 2 inches lower then the ROPS. I have never had any trouble getting it in the garage.
The back wind snaps in, like a Jeep. So I guess you could keep part of it open to the snowblower chute.
I pesonally like the Curtis cabs over the Sims. I design is a little better to me.
I had mine installed by the deal when I bought the machine, but would think you could do it yourself if you are handy. I would recomend that you get a heater and a fan.
/ Cab for B7800 #4
I have a Sims Soft Cab got it last fall and like it a lot. I pull it off for the summer, takes 5 mins to undo 8 bolts that hold it on. I looked at Curtus but it had a lot of plastic, rear and doors, on it compared to the Sims. The only plastic on a Sims are the doors, the rest is metal. I added the heater, got one off e-bay for $75.
/ Cab for B7800
Thanks for the inputs everbody.
Hey BrettW
I like your idea on a cap, but I'm more interested in keeping the snow off me more than keeping the sun of me.
Thanks for the input though.
Hey kokopelli2
I don't no why but I was thinking that the ROPS were inside the cab, thats why I was concerned about additional height.
I haven't had a chance to see a Curtis cab on a B7800 or B2910 yet.
Hey N.Y. Yankees Fan
Tom, I followed your advice from a previous post about the golf cart cover idea. I built a frame and top similiar to the pictures you had posted, but it turns out that a B7800's ROPS is taller than a BX series tractor ROPS and as a result the golf cart cover was too short. I suppose I could have tried to build a shorter frame that did not include the ROPS, but not including the ROPS would have made it more difficult.
The more I thought about it, the golf cart cover idea is more of a temporary solution and would probaby have lasted a few years, before replacing it with another golf cart cover. The zippered panel system looked a little tender to me especially in cold weather when the panels would have been stiffer from the cold, but a cab assembly for less than $200 is certainly an attractive alternative.
Thanks again for all the inputs.
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
(4) ASSORTED TIRES (A62613)
(4) ASSORTED TIRES...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
Landhonor 8' x 6' Metal Shed (A66408)
Landhonor 8' x 6'...
Tico Spotter Truck (A63689)
Tico Spotter Truck...
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
