C.V.A. injector pump problem
/ C.V.A. injector pump problem #1
farmboy55
Brown City, MI
Oliver 1850D
My Oliver 1850D is pressurizing return lines & filter housings to the point that
fuel is 'running" out of filters at the seals. Also rupturing return hoses. Any clues?
/ C.V.A. injector pump problem #2
Does it have a lift pump ahead of the filter? It must have if it's pressuizing a filter. Look for a stuck relief valve in the lift pump. It should not put any more that 4-5 psi into the injector pump. If it's overpressurizing the inlet of the injector pump then the return line pressures would be too high and give you problems there also.
2015 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2015 GMC Sierra...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
UNUSED WOLVERINE HYD ADJUSTABLE BALE SQUEEZE (A64281)
UNUSED WOLVERINE...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
Case skid steer wheels and tires (A63689)
Case skid steer...
2020 Cat 302.7D Mini Excavator (A64047)
2020 Cat 302.7D...
