C.V.A. injector pump problem
/ C.V.A. injector pump problem #1
farmboy55
Brown City, MI
Oliver 1850D
My Oliver 1850D is pressurizing return lines & filter housings to the point that
fuel is 'running" out of filters at the seals. Also rupturing return hoses. Any clues?
/ C.V.A. injector pump problem #2
Does it have a lift pump ahead of the filter? It must have if it's pressuizing a filter. Look for a stuck relief valve in the lift pump. It should not put any more that 4-5 psi into the injector pump. If it's overpressurizing the inlet of the injector pump then the return line pressures would be too high and give you problems there also.
2025 82in Rock Bucket Skid Steer Attachment (A61572)
2025 82in Rock...
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
UNUSED WOLVERINE QUICK COUPLER 1 (A64281)
UNUSED WOLVERINE...
