Bx2763a snowplow
/ Bx2763a snowplow #1
Brihart
Bx2230
Hi guys. I just recently picked up a 2763a snowplow for my 2230. My question is how do hook it up? I’d didn’t come with a manual so I don’t know where the hydraulic lines all go.
/ Bx2763a snowplow #2
If you have a loader on your machine follow the lines from the lift cylinders back to where they connect with the quick couplers, the lines on the loader typically will have a piece of tape wrapped around them (green, yellow, blue, or red...I think), then when you connect the plow you will know where the raise and lower goes, it should be the same function as the loader to raise and lower, back to raise, forward to lower and float, then just hook up the angle lines, same thing, push right to dump bucket should be angle plow right, push left to scoop bucket, angle plow left. you have a 50 -50 shot with hooking them up, worst case you can swap them around till you get them right.
Stout Brush Grapple HD72-4 (A66285)
Stout Brush...
8" Mini Excavator Bucket (A66285)
8" Mini Excavator...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
TERRA TRACK TRACKED WORK  VEHICLE
TERRA TRACK...
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
John Deere 1025R (A64126)
John Deere 1025R...
