BX2750 lubrication
/ BX2750 lubrication #1
gsmaneeley
Pulaski, NY
Kubota BX2660
I have a front mount BX 2750 snowblower and am trying to find an easier way to lubricate the chain. There is a cover plate over the chain. I was looking at an easier way to oil chain rather than removing the plate each time. (am I just that lazy or missing something) I am also looking for recomendations on the type of lubrication people are using. I presently use a chainsaw bar oil but was wondering if a chain grease like motorcycles use would work better?
/ BX2750 lubrication #2
I have used both. Still messy. The motorcycle chain grease I used comes out as a foam, not really wanting to spread. Once the foam breaks it seems like it wants to stay better on the chain than chainsaw bar oil. There is a plastic tube that comes with the motorcycle can stuff but when you spray through the guard hole it doesn't really go where you want it. I still pull the cover and spray with either and then rotate chain while in neutral drive. I only spray in beginning of season, mid season and end of season. Seems to be fine!
/ BX2750 lubrication #3
Use Fluid Film and the little red straw that comves with the can. You can bend it to go through the hole in the top.
/ BX2750 lubrication #4
I use bar oil in an oil can with a trigger and spout. I turn the pto on & let the oil drop through the top hole until the chain quiets down.
Thanks guy both ideas are going to work. got some fluid film and am figuring out a little spout to let it drip.
/ BX2750 lubrication #6
What I found to work for me is spraying through the two side holes on both sides and the hole on top. I am sure this does not get every link on the chain, so I try to lube the chain before each use.
Mini Skid Steer (A60352)
Mini Skid Steer...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
2018 International LT Automatic Day Cab (A62613)
2018 International...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
