Oil & Fuel BX2660 cold weather starting problem
/ BX2660 cold weather starting problem #1
vstar1300
Kubota BX2660
StARTS BUT DOES NOT CONTINUE TO RUN. Temperature 4 above.
Changed air filter,fuel filters. Now not starting.Lacking fuel flow.
Do I have to prime fuel line? How?
/ BX2660 cold weather starting problem #2
the bx's are self priming . just turn key on for 10 secs and back of and on again several times. it will bleed out.if your having issues - i'd check the feul . just like mine earlier i had mine gelled up. i swear i added the white power service back in october and i see crystals in the tank. i added 911 and sure enough it ran nice again.
/ BX2660 cold weather starting problem #3
Yes, your engine is self priming. I would second on the Diesel 911... sounds like you have slush in the tank.
Thanks for the advise. Fuel indeed started flowing and engine started. I have lots of Diesel 911 in the tank so hopefully that should keep it from gelling.
Temperature -5F this morning so will wait to put it to work.
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
JOHN DEERE 4450 TRACTOR (A59823)
JOHN DEERE 4450...
2017 Subaru Impreza AWD Hatchback (A59231)
2017 Subaru...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
