Sounds fine to me. Frontwards or backwards shouldn't have any affect. I wouldn't lift any with stabilizers since they will leak down and get slack in chains/straps if you had them doing any lift. Maybe strap/chain first then put them down but still no pressure on them.:2cents:I chain my BX25 down front and back, and put the stabilizers down. However, I have to load the tractor backeards so the stabilizers clear the wheel wells. Any problem with this?
My preference is to use chains in the rear (because they are stronger) and straps in the front. My logic is because you are much more likely to hit something and the load will want to move forward vs. a jack rabbit start putting minimal stress on the straps
Don't worry, I put NO pressure on the stabilizers. They are just touching the trailer deck in order to "widen" the footprint of the tractor.
What is the load rating on that chain?
It doesn't look like transport grade.
You could also be stopped for no strap on the bucket.
