BX25D. Mod #1 and continued.
/ BX25D. Mod #1 and continued. #721
The local guys I've talked to said they were pleased with the Speeco Quick Hitch. The cost was around $250. Land Pride at the Bota dealer was $495. plus tax. :thumbdown: I only installed it yesterday and it's off again today but I used it a few times and it was easy to install, easy to put the chipper on and locked in well. In the shop tonight doing the 50 hour service on the little guy.
Give an update (or start a separate thread) when youve had a few hours on the Speeco (if you dont mind). Im curious if it is a good value and whether it can take abuse like using a fully loaded box blade.
50 hrs already:thumbsup: Time flys doesnt it;)
/ BX25D. Mod #1 and continued. #722
94Bullitt gives an excellent review of the speeco vs JD, you may want to look it up.
Will do. I have a good local friend that has one on his Kioti and he just bought another one for his BX so that should tell you something. Didn't see any negatives on the net either. I'm just using it for the chipper,trailer tow bar I just built and a ballast box. I put the 50 hours on in two weeks but the next fifty will take a year now that I have phase 1 of my property done.
/ BX25D. Mod #1 and continued. #724
Great work in the Tow Guard. I'd say the whole job is better than factory quality.:thumbsup:
/ BX25D. Mod #1 and continued. #725
Probably obvious but I'm stumped, what is the pipe sticking out the rear for above the receiver ? Is it just a handle?
/ BX25D. Mod #1 and continued. #726
Its the quicker picker upper....handle.LOL One hand to pick up and the other hand to guide and connect.
Chris
Thank you very much. I was beginning to wonder if it was a flop :confused3: They can be a rough crowd you know! :laughing:
I did a quick search on it Ken and these guys like the Speeco. Pricing is right. 94Bullitt just said the visibility was better on the JD in the thread. I personally found the visibility OK on the BX.
http://www.tractorbynet.com/forums/massey-ferguson-owning-operating/273810-quick-hitch-3pt.html
/ BX25D. Mod #1 and continued. #730
Found that thread http://www.tractorbynet.com/forums/attachments/271390-john-deere-imatch-harbor-freight.html
So is the Speeco at Princess the EXACT same as the Harbour Freight? Or is the HF a clone of the Speeco?
Im asking because Im curious if 94Bullitt's observations are accurate for the one sold at PA. Looking at HF, they have it for $105 3-Point Quick Hitch for Tractors - 27-1/2" Clearance PA has it for $280! Looks like were getting the shaft here! 3-Point Cat. 1 Quick Hitch | Princess Auto
/ BX25D. Mod #1 and continued. #731
Looks great. I used the ETA 3 point trailer mover today for shifting equipment around today (haywagons, baler, hayrake, etc) and LOVE having the attachment point so far back. I can back a haywagon in as well with the L3830 as I can push it in with the hitch on the front of the RTV.
Aaron Z
/ BX25D. Mod #1 and continued. #732
The visibility thing may sound dumb til you use them both then you can see the difference. Nice job on the trailer mover.
The Harbor Freight is clone of the Speeco. I bet the PA is the same as the HF. I don't think the Speeco is much better than a HF other it comes equipped with the correct hardware.
/ BX25D. Mod #1 and continued. #733
4shorts: There are times I could use your trailer hitch protection mod on my truck! :D Great job! :thumbsup:
/ BX25D. Mod #1 and continued. #734
Let me ask a question (may seem dumb to some) why the Speeco quick hitch? Reason for question is two fold, first, I don't find it that hard to hook up attachments to the three point. Second, adding the quick hitch moves thins aft increasing the moment arm some and thus increasing the effective weight balance point aft.
That said I really like the tow assembly you made Paul. changing out the pins at the end would it attach directly to the three point? Keep those mods coming they hold my attention.
Thanks farmgirl. The protector was an afterthought during the building process. I was going to add gusset plates to the verticle arm and decided to use the Protector plate and it would add strength , looks (my opinion) and protection all in one.
There's no such thing as a dumb question in my opinion. The quick hitch was the answer for me. Trying to lone up everything to the 3 pt hitch was a royal pain for me. Now I just back into the implement, hit the two leavers and I'm hooked up. Its lightening fast. Yes It will decrease the lifting weight of the machine BUT in my case it didn't matter. I need to lift a ballast box, a chipper/shredder and the tow system and it can do that with ease. I feel if you add a quick hitch and it can't lift one of your implements your asking your tractor to do to much and you need a larger tractor IMHO. Yes I can knock out two split pins and the two pins will hook up directly to the 3 pt hitch assembly. Good questions :thumbsup:
Maybe someone else got a difference of opinion and that's great as well.
/ BX25D. Mod #1 and continued. #736
I believe the speeco is Made in China. That's why I prefer Deere's iMatch or Landpride. I really like my iMatch.
But yeah if speeco is same as hf... Save some money and get HF.
/ BX25D. Mod #1 and continued. #737
Someone must know if Speeco is the same as HF. That doesn't sound like it would be possible.
/ BX25D. Mod #1 and continued. #738
They teach the new welders on the harbor freight line. Once they get good they move them over to the Speeco line:laughing:
/ BX25D. Mod #1 and continued. #739
It depends on on who has been there most recently for a bribe run (I mean a plant inspection). When you schedule a trip to check out the work, they move the better welders to your line.
Aaron Z
(only half kidding)
/ BX25D. Mod #1 and continued. #740
We dont have HF here. We have its Canadian and considerably more expensive cousin, Princess Auto.
Thats why im trying to confirm if the Speeco is the exact same. The Speeco at PA is 2x the price of the HF (never on sale that I seen); if it is the same then were being royally shafted. If the Speeco it better quality, then maybe there is some value in the higher price.
That said, I wonder how the latch mechanism works? It looks like it would be an easy project to build.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
Woodland Mills Sawmill (A65579)
Woodland Mills...
PENDING SELLER CONFIRMATIONS (A59914)
PENDING SELLER...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
