Loader BX25 Loader bucket position while using backhoe?
/ BX25 Loader bucket position while using backhoe? #21
I have been running backhoes for 30 yrs . Union operator , #841 local . If you are dragging the hoe you need to work on technique . You drop the loader bucket to keep the machine stable . The front axle has a pivot . Try loading a tandem with the bucket up and the x hoe extended and you will understand . Do you think a real operator writes those books ? Yes you pick it up off the tires . When loading trucks they may be fully extended . You are a good bunch of people , but not an operator in the thread that I have seen . Kevin .
/ BX25 Loader bucket position while using backhoe? #22
I Angle my FEL to about 30ish degrees and put the blade in the ground a bit 1" or so. I do lift the rear tires about an 1" or so off the ground and use the stabilizers to level it. Never had a problem doing it this way---Guess it's my motto--"right way, wrong way and my way" :eek:
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2021 Polaris Ranger Electric Utility Bed UTV (A56859)
2021 Polaris...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
294 (A52706)
294 (A52706)
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
