BX24
Keithctc
I have a 08 BX24. The hyraulic pump seems to be a little noisy. It is especially noticeable when then a piston is fully extended or retracted -relief valve is operating. I changed the hyro fluid last fall and have not really used the machine very much during the winter. The fluid level is good. Did I need to bleed the system after changing the fluid? Thanks Keith
Sounds normal to me. You shouldn't need to bleed the system. I believe going to full direction to the stops up, down, left, right, curl, extend, etc. with the loader and backhoe bleeds those lines.
Like Singlecoil said......... your system is self bleeding. Simply running your functions fully will get any air out. Its perfectly normal to hear sqealing when your cylinders get to the end of their travel and your hand is still on the lever.
That squealing is the cylinders and relief valve saying "come on now, I aint got no more".....
Mind does that too....don't worry.
Craig
