BX24
   / BX24 #1
Keithctc
I have a 08 BX24. The hyraulic pump seems to be a little noisy. It is especially noticeable when then a piston is fully extended or retracted -relief valve is operating. I changed the hyro fluid last fall and have not really used the machine very much during the winter. The fluid level is good. Did I need to bleed the system after changing the fluid? Thanks Keith
   / BX24 #2
Sounds normal to me. You shouldn't need to bleed the system. I believe going to full direction to the stops up, down, left, right, curl, extend, etc. with the loader and backhoe bleeds those lines.
   / BX24 #3
Like Singlecoil said......... your system is self bleeding. Simply running your functions fully will get any air out. Its perfectly normal to hear sqealing when your cylinders get to the end of their travel and your hand is still on the lever.
   / BX24 #4
That squealing is the cylinders and relief valve saying "come on now, I aint got no more".....
Mind does that too....don't worry.
Craig
Deere 9970 Cotton Picker (A52128)
Deere 9970 Cotton...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
